Konica Minolta bizhub C250 All-In-One Laser Printer Logo
A
Anonymous Posted on Jun 19, 2014
I am receiving an error code: 0x80070035 - Konica Minolta bizhub C250 All-In-One Laser Printer
Mike walsan
Level 2:
Sergeant:
  • Expert 161 Answers
  • Posted on Feb 07, 2019
Mike walsan
Expert
Level 2:
Sergeant:
Answers
161
Questions
18
Helped
22846
Points
529
Steps to Fix Windows Error Code 0x80070035 ( https://www.errorcodeexpert.com/error-code-0x80070035/ ) The system way was not found the Error code 0x80070035 The system way was not found can occur for a wide range of reasons, this guide will indicate you many general goals for this issue.
This issue influences all version of Microsoft Windows. The error is caused by some sort of authentication issue, I have seen this error 0x80070035 The system way was not discovered the most on windows machines connecting to share which are facilitated on non-Microsoft Operating system, for example, Linux.
Resolution 1 - Change LAN Manager authentication level
At the point when a Microsoft machine tried to get to an offer, it needs to confirm before it can get to the resource. At the point when a Microsoft Windows machine trie to get to an offer on a non-windows machine (Linux for instance) the validation, some time can come up short on the grounds that the remote machine can not understand the format of the authentication sent.
I would say this is the no doubt reason for the Error Code 0x80070035 The system way was not found, so we have to change how the authentication request is sent, we will need to perform the following steps.
Click on your start menu type in secpol.MSC then left click on the application that shows up
Then browse to the following location Local Policies > Security Options > Network security: LAN Manager authentication level and double click the setting "Network security: LAN Manager authentication level.
From the drop-down box select "Send LM & NTLM-use NTLMv2 session security if negotiated" then click on apply then ok. Now restart your machine and try to access the share that you got the error on before.
jinenth
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 20, 2014
jinenth
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
125
Points
Hi this kind of errors how came u should mention frst
may ne after you removed the board and then came ?
or while working suddnetly came ?
please specify
CD player displays error code: ER-1
That error code means an unknown error has occurred. Try cleaning the player itself, along with the CD's prior to insertion to see if that helps.
Error 45 on opening e mail, solution
Problem loading message: Error Code 45If you received an error code 45 when attempting to load a message, you'll need to contact us to resolve this error.
To contact Yahoo about receiving an error code 45 message:
  1. Select Contact Customer Care on this page to go to the help form.
  2. In the form, select:
    1. Your version of Yahoo Mail
    2. Category: Notices and errors
    3. Sub-category: Received temporary error code
  3. Provide these details for at least one message that produced this error:
    • Contact name and email address
    • Date message was received
    • Message subject line
    • The folder containing the email (Inbox, Spam, etc.)
    • How you attempted to open the message when the error displayed (from a folder, from email search results, etc.)
Sep 05, 2013 • Yahoo Mail
Error code 04ee on Dish network 722 vip HDD,
Hello this is luke. I do not know of any 04 ee error code on dish network. The closest will be 004. Try to check if it is coming from the receiver or from the tv by unplugging the receiver from wall outlet while tv is on. If the code stays, then it is from the tv, if it goes away with the lights on receiver, it is from the receiver. Let me know.
2answers
No net connectivity
If you encounter difficulties accessing computers that are visible on the network map, make sure the computer being accessed has an account with the same name/password as the system connecting to it uses to login.
To set up Network Sharing between XP and Windows Vista, please note that File and Printer Sharing is different in Windows Vista than from the setup in Windows XP.
On a computer running Windows XP, click Start, click Control Panel, and then click Network Connections.
Click Local Area Network Connection, click Properties, and then view the list of items used by the network connection.
Ensure that the Link-Layer Topology Discovery Responder check box is selected.
Fax Recive Error on sharp MX2300-N "receive impossible"
Communication report codes
46 NO RESPONSE The FAX signal from the remote party is not detected within T1 time. <Send/Polling>
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
