RCA 39" class LCD HDTV 39LB45RQ - ON Corp US, Inc Logo
Tom Rushing Posted on Jun 15, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Picture upside down
I replaced the main board, then picture was upside down.
Jerry Greenberg
Level 3:
Genius:
  • RCA Master 1,691 Answers
  • Posted on Jun 15, 2014
Jerry Greenberg
RCA Master
Level 3:
Genius:
Answers
1691
Questions
Helped
735844
Points
3767
Check that the connectors are properly put on. In some models of TV sets the connectors are not keyed, and can be inserted in either direction. This would be obviously the connector that is carrying the image data to the screen.
If this is not a reversed connector, then it is most likely a firmware issue in the new replacement board. Make sure the replacement board is the exact one required for your model type.
1helpful
32 element tv I replaced the power supply board but the imagen appear backward could you please help me, i'll appreciate. Jamie
I assume this set has the power and main board combined as a power board will never make the picture upside down. What happened is you got the wrong board, on element sets you need to order by the small paper sticker number not the board number, you have 2 choices...get the right board or turn the set upside down
1helpful
Vizio tv 42 inch main board replace
Compare the two side by side, double check your connections,check the pins,are they in the same line up +/-, did you ground yourself before doing the install
Rca screen is upside down.
maybe you need to change the setting ( model ) from service mode)
I have fussion led 32 inch tv i pressed reset it turned picture upside down how can i fix it
Go to service mode and there should be an option to flip the picture, not sure why this should happen when selecting reset as its more common when replacing the main board
LVDS issue with RCA 46 inch LCD TV
If you wish to get some details; check the site linked here. Pull up older posts.
Reasons for upside down picture are given.
Hello, I have Samsung TV Model: UN60ES8000FXZA. I replaced the Main board, TV works fine, except the upside down picture. How to fix this problem, I need to get special codes.The same picture on the M
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
I have an insignia 46" tv I replaced the main board, the tv works except the picture is upside down, what will correct this problem
Flip the TV over! Just kidding!! When you installed the main board was it identical to the old main board? If so, you might want to look at the old board and ensure there are no jumpers that needed to be set on the new board. Some companies make generic control boards for tvs but have different jumper settings for different models. The jumpers are just little black blocks that connect different pins to each other on top of the circuit board.
2answers
I replaced my main board on a 42lb45rq now my picture is upside down
Configure Windows "video" properties to have Windows "rotate" the picture 180 degrees, i.e., make Windows produce "upside-down" output, and the screen will "flip" that output.
Thomson 27lcdb03b picture upside down
I would suspect main board more than one you replaced--not likely to get help as Thompson is not known for that--possible firmware upgrade seems likely.
On every set I have seen with upside down/inverted or reversed screen etc it has been either a firmware issue or a main board.
2answers
UPSIDE DOWN PICTURE
Check in the setting of your webcameras control panel and see if there is an option for changing the view.
Jul 23, 2008 • A4tech PK5
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
