Doub;e chk your wiring like you did a dozen times before I came along. Ok, the GFI IS FUNCTIONING AS INTENDED. wHAT IT DOES IS SENSES ANY DEVIATION BETWEEN THETWO WIRES.(WHT and blk.) aNY CHANGE IN CURRENT FLOW PATTERN IS READ AS A GROUND FAULT.sHOULD SOMEONE OR SOMETHING CAUSES OR creates an alteernate pathto ground,, The neutral pattern is altered resulting in circuit interuption via the GFI. You can see how altering either blk or wht current flow that would or could cause a shock would create the need for the Ground Fault interupter. The fan and lamps utiilizeavailable current. They do not or are not supposed tocreate a new path, which is what is happening. I am inclined to say it's a wiringproblem. chk to see if the wht (nuetral ) is secure and properly grounded n the power pane. The delay with the fan is indicative of a heat issue. The panel breaker may be heating up and faulting the circuit. Circuit breakers are positive contacts but, worth checking. If you have another, switch them out and see what you have.. Good Luck and of course, be safe, be careful. -Ned
Sounds like the breakers are working.
SOURCE: Eaton Arc Fault Breaker type BRAF tripped.
My arc fault breaker trips in my bedroom when ever a load is put on line. The trunk line comes into a three gang switch box and feeds the entire room. At times I can turn my ceiling fan and light on for 10 to 20 minutes before the breaker trips. Other times the breaker will trip when either switch is first turned on. I plugged a 4 watt night light in a wall receptical, without the ceiling light or fan on, it also trips the breaker. I have had other plug in lamps, 60 watt, work in other recepticals for a while. The problem seems to appear in all recepticals and lighting in the room.
