SOURCE: I HAVE A COOLPIX model
You should just try Picasa 3. Its simple, easy, and you don't need any complicated programs. You just plug in your camera, go to Picasa, and press import!
SOURCE: cannot register my nikon coolpix s210
you did not answer my question! i merely wanted to know how i register on line for the camera i purchased.
judy boyer
SOURCE: Coolpix S210 Black Screen
Normally there are two reasons for the given problem.
1). Bad or defective CCD. and/or
2). shutter not working.
in
the first case the only solution is the replacement of the CCD. and in
the later case sticking of shutter blade, non functioning of shutter
blade will cause the problem. This can be rectified by sending it to
some repairer.
SOURCE: Computer can't "see" our Nikon Coolpix S210 camera anymore
Do what the pros do...use a card reader.
SOURCE: my coolpix S210 lense will not go in. Showing lense error on scr
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to auto focus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
