Mitsubishi WD-65736 Television Logo
A
Anonymous Posted on Feb 02, 2018
Re: WD65736 DLP High Def TV. Powered it on and heard a "POP". We now have no sound or picture. Tried reset button and unplugging and replugging the set but nothing has changed. You can hear the fan start up and run the green light comes on but then it will shut down.
Russ Hill
Level 3:
  • Mitsubishi Master 4,057 Answers
  • Posted on Feb 02, 2018
 Russ Hill
Mitsubishi Master
Level 3:
Answers
4057
Questions
10
Helped
1177883
Points
12696
Pop sound i would think a main capacitor has gone, on the power board. it could be just the capacitor or the voltage regulator has gone as well and blown the capacitor. it could also be the diode that has for pins has + & - on it with 2 squiggly lines on it when this goes it can go with a bang and there will be no power light or anting, and it also blows the 5 volt side of the tv. so all the parts would need replacing.
  • Larry Feb 02, 2018
    Replace the power supply board and all should be well
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Jul 08, 2007
SOURCE: 42" Mitsubishi 52525
You may have bad capacitors in the DM board.
Vista Electronics
  • 1694 Answers
  • Posted on Nov 22, 2007
SOURCE: mitsubishi ws-55613 55in.
Four bad capacitors in DM module = common repair for
qualified Mits tech.......................T.
Anonymous
  • 106 Answers
  • Posted on Dec 19, 2008
SOURCE: STATUS LIGHT SOLID RED ON 73 DLP MITSU MODEL WD73735
The colorwheel is your problem. To confirm this, unplug the tv, then listen thru the air vents in the back as you plug the tv in. You will probably hear a ticking sound. If you do, that is the colrwheel. If the colrwheel is working, youwill be able to hear it "spin up". It will be a sudden high pitch whine. Let me know if I can be of further assistance
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Apr 03, 2009
SOURCE: mitsubishi-ws55859 power failure flashing timer green light
the capacitors on the DM need to be replaced. Very easy repair you can get the repair kit at this link which is for your model it contains the replacement capacitors and step by step insturctions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Oct 14, 2011
SOURCE: I am getting error code 34 on my DLP TV. the bulb
the 34 error is a lamp abnormality, So if the lamp is new the Ballast or the Power Board could be the issue however the ballast would be more suspect.
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
3helpful
Have a 65inch Mitsubishi DLP. acouple years old, just heard a loud pop,smelled like it was burning,it turns on but just sound????
hi,
Check the lamp of you tv. The lam is burned. that's why you heared a pop up sound and burning smell. Just check it and replace it. you will get the picture back.
ok
Hey, i bought a DLP Toshiba HDTV off a guy on graigslist, when i went to go pick it up he turned it on by remote and everything worked fine as it should. When i got back to my place I tried turning it on...
These DLP tvs sometime u unplug suddenly and replug it back wright away,tv will go into protective mode and will not work wright away.Tries tv unplug,replug it back about an hour later,now the tv will reset itself back to the factory setting.The tv should work now.
Tv was moved from fl to al. When the tv was unpacked and connected the power button on the tv was pushed. It sounded as if tv powered up.. Heard two clicks and the tv turned off. Help?
Unplug the tv about an hour,replug it back in,to let tv reset itself.The tv should work again.Not,take out the back cover,check all connections,see if any loses connections.
2helpful
2answers
Does my set have a reset button?
No,try unplug,replug an hour later that ur reset.If same thing, ur video backlight board it dead.need it replaced.
1helpful
2answers
I replaced the lamp on my wd65736 mitsubishi .but
Do you get a red light on the front of the set comming on alerting you of a bad lamp? Did you place the cover back on correctly after placing the new lamp in the TV?
Heard a loud pop and picture went out. Still have sound
Ur tv have burns capacitors,look for pop ups caps.
VIZIO RP56 problem with the pictures
I heard a pop sound, and now there is no power to the VIZIO RP56... found the lamp to be out.
I replaced the lamp, and now I still don't have power to the TV
confirming the outlit is working and it's hot, I unpluged, and repluged the power cord, still not power to the TV?
1helpful
4answers
JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
