Tag Heuer F1 Indy 500 CAC111B.BA0850 Logo
A
Anonymous Posted on Jun 10, 2014
Sons watch has suddenly stopped minute hand is working any ideas the watche is two years old and has not been serviced
5 Related Answers
Anonymous
  • Posted on Feb 05, 2009
SOURCE: Tag Heuer CA 1211-RO Min. Hand resets to 59 Min.
Unscrew the crown and pull out halfway. Use the stopwatch buttons to advance the hand to where you want it. Then push the crown back in and screw it down. You may need to pull the crown out all the way--I cannot recall which setting controls the minute hand and which the hour hand on the stopwatch function. This has to be done every time the battery is changed.
Anonymous
  • 4 Answers
  • Posted on Feb 16, 2009
SOURCE: watch second hand
I had the same problem with my Tag. Same 4 second jump. It's definitely the battery. I'm surprised at only 3 months, but maybe it sat a while in the display case. Mine was over a year and a half.
Anonymous
  • 18 Answers
  • Posted on Jul 09, 2009
SOURCE: Stop Watch not resetting
pulling the crown out to position 2 and pressing button to zero it out one increment at a time is the way to do it do touch the watch hands. Works on fossil watches as well as tag watches
Anonymous
  • Posted on Nov 01, 2009
SOURCE: How do you get a GapKids watch out of military time?
press the mode button 3 times and it will be on time setting press restart until the hours are blinking then hold the start button til it says am or pm
Anonymous
  • Posted on Mar 08, 2010
SOURCE: tag heuer link automatic
exact same problem, no one seems to know
1helpful
Hello. I have a Seiko 7t62 ojpo chronograph. The small second hand will run for about 20 minutes then stops. As a result, the main minute and hour hands stop working. Everything else works. Any ideas?
You have a fairly premium watch and some versions are more premium than others. Your watch clearly needs attention and that should be entrusted to a Seiko dealer or to the manufacturer. Once the case has been opened the sealing must be retested to ensure it meets specification. If this isn't done as part of the repair or service or battery fitting there is little point in having a watch with such a high specification.
1helpful
Rolex Sumariner with Date submersible to 300metres
your submariner is an automatic movement that needs to be serviced every 3-5 years to replenish the oils and to stop any wear or tear on the movement the regulation is part of the service
1helpful
My CK 2247107 watch is one year old now, Suddenly the watch stopped running, Surely cannot be the battery. Do i need to change any mode. I tried setting different modes on the pushbutton to reset the...
mcdevito75 here, One year old, most likely the factory Battery and at 1 year old the battery is old, who knows how long the battery was in the watch before you bought it 1 year ago?? The battery is the first suspect. Look for a small watch repair shop in your area for a new battery first.
Feb 09, 2011 • Watches
6helpful
I'm trying to set my son's Timex 1440 watch. I can get the minutes blinking but when I touch the top right button it only moves the minutes in 30-minute increments. So i can set it at 8:30 or 9:00, for...
I had the same problem with the watch my wife bought me. On the mode make sure it doesn;t say T2 in the top right hand corner. if it does you are in the wrong mode. Hit the mode button until it shows the day of the week highlighted and a date and then go through the normal time set procedures. That worked for me.
2helpful
My kinetic purchased in 1995, started to not fully charge and show a full charge. It runs only a short time before stopping, this happened suddenly after years of perfect operation. The watch is in good...
It is a little old but should give many more years of service. I suggest that you have it cleaned, this should make all the difference.
Since these watches contain a battery it might also be a good idea to have a new one fitted.
3helpful
I have a Seiko Titanium Chronograph certified water resistant to 20 BAR. The movement # is 7T62-0BZ0. I recently had a jeweller put a new battery in the watch and it has not been working properly since. I...
DO AMASTER RESET TO YOUR WATCH!PULL FULL OUT THE STEM(CROWN)THEN TURN THE HANDS TO THE RIGHT TIME THEN RESET THE CHRONOGRAPH AND THE ALARM WITH THE TWO BUTTONS(SEE YOUR MANUAL.IF YOU HAVENT TRY TO DOWNLOAD IT FROM ANY SITE OF SEIKO SUPPORT).THEN PUT THE CROWN IN.IF THE PROBLEM REMAINS THE ONLY SOLUTION IS THE SIKO SERVICE!THEY ARE NOT EXPENSIVE AND MAKE GOOD WORK!DONT GIVE THE WATCES EVEN FOR THE BATTERY TO THE MONKEYMAGICIANSGURU JEWELERS THEY ARE WATCH RUINERS!
5helpful
Minute Hand on Stopwatch Will Not Return to Zero
Here is the link where you can download manual for your watch:
http://www.seikousa.com/pdf/SNA_Series.pdf
The last chapter explains how to reset hands to zero.
Do not forget to rate, please.
I cant adjust the minite hand backwards if the watch is gaining
Unfortunately your watch do not have reverse action, so, you have to go all the way forwards till you reach designated time again.
One more way how to set the right time is to disconnect the battery and wait till the real time reaches the hands of your watch, then put battery back and set again. If watch has a STOP function (crown pulled out), then you don't have to disconnect the battery- just pull out crown and wait.
By the way: pushing the button in accelerates minute hand constantly, but if you'll push the button rapidly, it will move mimnute hand bit by bit. Use this feature to set desired time more precisely.
6helpful
2answers
Casio 4305 runs 5 minutes slow.
No reason to panic as your watch hands can be advanced to desired time. Her is the link for your watch users manual download:
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=4305&submit.x=52&submit.y=12
Save it on your PC and follow instructions how to set the time.
Don't forget to rate, please.
Jan 05, 2009 • Watches
2answers
Casio 2688 Wave Ceptor - No Display
On the solar charge watches, they use a chargeable Lithium battery. It is NOT an off the shelf regular battery! It is best to send the watch to the factory service rep in your area for a battery change.
In many of these models the battery is using solder contacts to the circuit board. The person changing the battery will require the original spec battery, and be equiped to do surface type soldering.
When working on this watch, the factory service will change the seals and do a pressure water resistance test. The regular corner watch service store is not equiped to do this type of testing.
Normaly, the battery in solar watches should last more than 5 years. Some are going past 10 years!
Jerry G.
Top Tag Heuer Watches Experts
k24674
Sean Wright
Sean Wright
Ngoro
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
