Error Code ( E-23 )--------Clean the LID LOCK sensor,its almost located where you can see the LID LOCK came OUT and IN or Moving--which is functions to LOCK and UNLOCK the door cover ( Symptom ++ the LID LOCK will moving OUT and IN),open all the cover ,take out the LID LOCK sensor,open the LID LOCK sensor case until you can reach the COPPER connector which is act as the SWITCH .CLEAN the COPPER with paper sand or anything possible but not to damage the copper.After all put it back to the place intact.Hope it work,Mine worked with this procedure.+++++Toshiba AW-SD120S COST=== FREE OF Charge ( Do It Yourself )
How to fix e25 error in toshiba aw-d980sm washing machine
SOURCE: Error Code E23
Hello welcome to Fixya
E23 means
The drain pump relay on the control board has failed.
Fix: Replace control board or wire!
you can see schematics and diagrams at the site below, and order parts from them if you want.
Or call service!
http://www.pcappliancerepair.com/model-display.php
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
SOURCE: Affinity Front Load Washer E21 first, now E23
E21 Water not pumping out fast enough. Refer to test (3). E23 Drain pump relay on control board failed or wire off pump. Replace control board or wire. 1. Check the drain hose for restrictions. Restriction. Correct problem. No restriction. Go to step (2). 2. Start the washer and check for 120 VAC at the drain pump. Zero. Replace the control board. 120 VAC. Remove the pump and check for blockage. If blocked, remove the restriction, if not, replace the pump.
SOURCE: E23 error code
this is a drain pump relay on the control board failure.you either need to replace the wire or the main control board
