https://apollogateopeners.com > store > 1500-160...
PDF
Read the owner's manual. Have a qualified service person make repairs to gate hardware. • The entrance is for vehicles only. Pedestrians must use separate ...
Follow
these steps to program your URC R6 Universal Remote control:
Turn on the component you want to program.
On the AVEX R6, press the Component button that you
want to program and the SELECT [SEL] button at the same time. Hold down
both buttons for 2 seconds until the TV Component LED light turns on.
This signals that you are in programming mode.
Enter the three digit code for your component. If this
is the correct three digit number, your device will turn off.
Press the component button you just programmed (in this
case TV) one more time to save the code number. The component LED light
will blink three times to confirm that the code was successfully
stored.
I hope that helps. ____________________________________________________________________ URC-R6 Manual Download
open the control box
press program button the press open on the remote and let it learn from the box
it should fully open then fully close to learn the cycle
hi,
You have to oppen the motor control pannel. There will be circuit board inside it. In the circuit board you can see a Push button switch. It is the learn switch.
After powering ON press and release immediatly this learn switch. With in 30 seconds press and hold the button you wish to use until two click heard from the control board.
If you can sent me your email id through FixYa then i will sent the picture which shows the learn switch.
OK.
On a D5 Motor To program the first remote place the jumper on in learn mode over J2 and Central Pin after it has completed flashing remove the jumper. Press the button on the remote you want to program, wait until the gate starts moving. To program addtional remotes use the master remote. First remove the jumper so that the 3 pins are exposed. Press the button on the master remote and hold it in. Notice that the LED next to the pins starts flashing after it has flashed 11 times release the button. Now press the button on the second remote and hold it in it should learn the signal.
There was a minor change for mine to work.. see below..
- you must park your Prius close to the gate opener, leaving it running (obviously not in the way of the gate closing) - Hold the button the the mirror and then push your garage door remote button and hold until the light on the mirror starts to flasyh fast. THIS programs the button on the mirror, but not the garage opener - yet (this was key for me) - locate the "learning button" on the opener itself - press the "learning button" on your gate opener and then get back into the Prius within 30 seconds (more time than it sounds) and press the SAME Homelink button you just programmed above. I don't recall how long I held the pre-programmed button, but the light will flash as I recall. - Then, when working the garage door, you may need to hold the mirror button for a good second for it to work - but I had tried for months to get mine to work, and finally after reading many posts, the above sequence worked on my 2008 Prius with my Lift Master, Security + rolling codes garage opener.
Just - program the button on the mirror with your remote FIRST.. the garage opener will not work.. then use the Learn button on the garage opener and the SAME BUTTON you just programmed.. and it worked great for me. Not programming the mirror button first will not work. Using only the Learn button will not work. You must program the mirror first with the remote, then use the learn button and the SAME button on the mirror. Hope this helps.
Scott 2008 Prius with Lift Master Security + opener. -
The Learn Button is in a Silver little metal box that is in the opener housing but separate from the opener itself, pry off the case which kinda wraps around the reciever, it will say liftmaster of chamberlain the learn button will be in the reciever
