Good Morning Friend, I am happy to assist you!
I understand your Electrolux washer is getting an error code E58. It could mean a number of issues, but primarily that the motor is overheating or a higher-than-usual motor current caused by other issues. Typically, an experienced technician would remove the belt to check the motor and motor pulley to ensure all is in working order first. Their next step would be to check the tub pulley and tub bearings. Last items they would examine would be the drive motor and speed control board by ohm measurement. Once the tech has ruled out a number of possibilities, he or she can pinpoint the exact problem and the necessary part to fix the issue. Since parts can often be quite costly, I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts.
Hope this helps! - Z
SOURCE: washer stuck error code
only thing u can do is ring the manufacturer u should have there tel no; on your manual seems to me like these makes of washer are having alot of problems better of sticking with hotpoint or bosch they are good washer that dont break done easy
SOURCE: error code E10 on frigidaire
I have the same problem. I'm going to search the frigidaire web sight
SOURCE: error code 70 for frigidare gltf2940es front load washer
Please visit the below mentioned link to view a list of error codes of Frigidaire front load washer:
http://www.scribd.com/doc/8559708/Frigidaire-Affinity-Front-Load-Washer-Error-Codes
Thank you
SOURCE: e10 error code
1 beep and E10 is listed as the dispenser door is open. Try reclosing your soap dispenser door tight.
SOURCE: Front Load Washer will not
This is an error code for a slow drain or no drain at all problem. It can be due
to a clogged/kinked drain hose, blocked drain filter/coin trap, or a
broken drain pump. The link below provides the detailed troubleshooting
procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Hi friend, thank you for your inquiry!
On an Electrolux washer the error code "E00" stands for No code stored. This could be a miscommunication I would recommend you perform a reset on your washer. You can do this by flipping the household breaker for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your washer continues to display "E00". I look forward to assisting you. -Matt
Check the wire harness between the controller and the motor! This assembly is most likely the culprit due to the wires being cut over time due to tight wire ties and the vibration.
Not a hard DYI fix.
