SOURCE: Watch Problems
PROVIDE US HERE THE WATCH MODEL..
AND ALSO PROVIDE A DETAILED PICTURE IF POSSIBLE...
SOURCE: How to set kenneth cole unlisted digital watch with 4 buttons
OK I'll do my best to describe the procedure...
Part 1:
Press mode button till the seconds window blinks
Press Lap/Reset button once to make minutes blink
Cycle through minutes using Start/Stop Button
Part 2:
Press Lap/Reset button once again to make hours blink
Cycle through hours using Start/Stop Button
(for this part, it's a bit tricky. Hours can be displayed in AM, PM, or 24 hour duration. AM is represented by "A", PM is shown with "P" and 24 hour mode is shown with "H", so keep an eye in the seconds window when setting your hour so you know for sure if you have the right hour)
When your done setting minutes and hours, press mode button again till you get to main screen
A helpful hint is to remember when setting up anything in this watch, mode will cycle through the different screens, lap/reset will change the value of whatever your modifying (AKA minutes/hours) and start/stop scrolls through the different fields.
Hope this helps. Sorry if it's confusing, best I could do.
SOURCE: I need instructions on how to set day, date and
These wacthes are made by the Geneva Watch Group. Their web site is http://www.genevawatchgroup.com/
On the right of the screen is a menu, choose "our brands and then scroll down until you find the instructions for your watch.
SOURCE: Kenneth Cole Unlisted watch, no instructions on
http://safemanuals.com/zearch_7808.php
Your best bet for a manual
SOURCE: Watch settings
Press MODE and it jumps to Timer. Press mode again and jumps to ALARM set. press MODE quickly and jumps to time set. press START/STOP to reset and press RESET to change to minutes or hours. press RESET again and changes to Date Set...
http://www.genevawatchgroup.com/pdf/unlisted/UNLISTED-GENERAL-ANALOG-DIGITAL-INST.pdf
