Televison & Video Logo
a
art ramirez Posted on Jun 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Car cranks, no spark to plugs. 1982 Buick skyhawk. How do I trobleshoot
william rodriguez
Level 3:
  • Master 958 Answers
  • Posted on Jun 05, 2014
william rodriguez
Master
Level 3:
Answers
958
Questions
Helped
169651
Points
2511
If no spark then you need to check the coil pack it sounds like it may be the problem..
1helpful
2answers
I have a 1982 Buick Electra, 8 cyl, but my car cut off while driving and won't start. New battery was installed 5/20 the days before it stopped while driving.Alternator, starter new, but wont start
Make sure battery has a full charge and battery connections are all good. Have a helper crank it while you check for spark at the plugs. If spark everywhere, check fuel pressure.
Is this vehicle computer controlled?
1helpful
My 1985 Skyhawk won't start. Cranks well but no start
BAD COIL OR IGNITION MODULE INSIDE DISTRIBUTOR RUN OHM TESTS TO VERIFY
Computer, ignition coil, ignition module has been replace but still no spark occure on the spark plug
it sounds like there is really only one more component to check - check the rotor in the distributor cap and cap itself.
c...
How do i get to the back three spark plugs
The check engine light ,has to do with ,is the gas cap tight? or the engine is burning RICH and the computer kicks it LEAN and then it kicks back RICH ,then it doesn't know what to do so it puts the check engine light on! it is ok to drive,fuel mileage may be lower. in a lot of cars it has to do with" ignition key cycles" put the key in ,turn it on crank it let it run,turn off ,take key out ,that is one cycle i know with some cars its 20, and some others its 54,your car may have what is called a OBDII .,plug ,under the dash ,a code reader ,could read the code and clear them ,THERE is something else ,that may work with my skyhawk,buick to clear code i could unplug the ---- negative side of the battery and wait 3 minutes and tighten it back on,you'll have to reset your radio
1983 buick skyhawk 2.0 with TBI not sparying fuel
change the crank sensor.No the ECM has no internal oil components
Top Viper Televison & Video Experts
Paul Bade
john h
ADMIN Andrew
ADMIN Andrew
Are you a Viper Televison and Video Expert? Answer questions, earn points and help others
