If you are referring to a chipset replacement look online for a company that does this, and has a BGA Rework Station.
Not only will they have the proper tools, and expertise, they will also have access to the chipset/s needed.
You may find the price of replacing will outweigh the cost of simply just replacing the motherboard.
If you are referring to an Electrolytic Capacitor, any competent computer repair shop should be able to handle this.
Note I stated, "Competent".
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131394Shouldn't cost that much. If it does seek a, 'Mom and Pop' computer shop.
{If you have decent de-soldering and soldering skills you could do it,
http://www.capacitorlab.com/visible-failures/index.htmhttp://www.capacitorlab.com/replacing-motherboard-capacitors-howto/index.htmIf you repair/replace, I suggest using a 25 to 40 Watt soldering iron, .030 Rosin solder, Solder Wick, (Desoldering Braid), instead of a Desoldering Tool (Solder S-ucker Tool), patience, and a steady hand,
http://www.mouser.com/Passive-Components/Capacitors/Aluminum-Electrolytic-Capacitors/_/N-75hqt/The Electrolytic Capacitors used on your motherboard are Radial Aluminum Electrolytic Capacitors.
For additional questions please post in a Comment.
Regards,
joecoolvette
