Drain is not clogged but curious if there is a filter needing cleaned
SOURCE: Kenmore 44072 Front Load Washer Drain Hose Cleaning
Try this link for step-by-step instructions. More than likely you will have to clean the drain pump as well.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If you are having trouble draining the water from the wash tub, and cannot get it to drain with a shop vac, you can drain it directly from the tub. If you don't own a shop vac, you may have to bail. If your drain pump does not have a clean out trap, remove the inlet and outlet hoses to access the inside of the drain pump. Inspect the pump impeller for obstructions and/or damage. If the water will not drain when you try to pull a vacuum on the drain line, you may have to disconnect the drain hose from the bottom of the wash tub. In some front loaders, there is a ball valve in the drain hose from the bottom of the wash tub to the drain pump. This ball can act as a collection pint from lint and debris. You will need to remove the hoses from the bottom of the wash tub to clean this area. I would recommend doing this as a LAST resort. Often, it can be difficult to reconnect this hose to the tub and get it to seal correctly. I hope this helps you. Please post back if you need further assistance.
SOURCE: kenmore elite he3t washer
remove fill hoses at wall and washer ends look for a screen in hose at faucet end and 1 in washer fill valve pull and clean them be sure to reinstall screens before reconnecting..also fluch hoses out after reconnecting to faucet end and before reconnecting to washer to flush any trash/sand that be in them
SOURCE: LG front loader not draining properly
My LG front loader is stopping during the drain cycle (making a humming sound as if it is trying to drain, but can't....What can I do?
SOURCE: Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
SOURCE: kenmore 44152 3.5 high capicity washer will not spin
Open the lid of the washer and let it down gently to see if you hear a click when it closes. There is a lid switch that sometimes fails and prevents the washer from going into a spin cycle. If you don't hear the click when the lid closes, then you may need to have the lid switch replaced.
http://tclaundryrepair.com/home
Hi
This issue usually occurs due to kinked drain pipe, clogged
drain filter or drain pump. First make sure that the drain is not clogged and
remove clogs if present. If no visible lint is present then remove the lower
front access panel to check the drain filter and drain pump for any clogs,
you'll need to clean the drain filter and drain pump completely. Hope this
helps... Please post back for any further assistance.
Daniel
