Haier HVW18BSS 18-Bottle Single-Zone Wine Cooler Tower Storage Logo
Posted on May 30, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an Haier model HVW18BSS wine cooler. The two fans needed to be replaced and I can't remember if both fans blow air towards the unit or just the top one and the bottom fan exhausts or do both exhaust?
Bhabotosh Chakraborty
Level 2:
New Friend:
  • Expert 138 Answers
  • Posted on May 30, 2014
Expert
Level 2:
New Friend:
Answers
138
Questions
0
Helped
27884
Points
262
I have a Danby Silhouette wine cooler model DWC512BL. Fan in the back started making noise, I called a technician, he told me the fan was bad, removed it (cut the wire) and sai I had to replace the fan. It...
For those refrigeration systems that employ a fan it is usually positioned to push cool ambient air through the condenser, being somewhat more efficient than pulling air through it because unless it is fitted with a close fitting mask or cowl the fan could pull a great deal of air from the sides completely bypassing the evaporator...
MODEL #HAW18ABB
www.haier.com/us/servicesupport/overview
Have a Haier 18-bottle wine cooler. In 3 occasions since I bought it I'v needed to unplug it. Every single time I plug it back it will not work. 1rst & 2nd time, fans stopped working, they sounded...
I don't know. It might just be really old? If you bought it like in 2000-2005, it might just be old. You probebly just need to get a new one. Don't feel bad. :3
1helpful
Wine fridge is always running but never cools below room temperature.
the processor cooling fans for the CPU and case fans are 3 PINS.. you can use them but remember that these are 12V fans. once its the same power it will work. Ps if needed you can cut the connects from your old fan and connect it to the new ones to get it to fit properly..
1helpful
I have a Haier HVST18DABB wine cooler, and the upper fan has stopped working (appears to have seized up). What are my options for replacing the fan? I have removed it from the unit, and it is marked...
Hi Bill,
Not sure if you got an answer to this question or not, but I had the same issue and thought I'd reply just in case you still needed help. I was able to order this part for about $30 (including shipping and tax) from http://www.partstore.com. The item number for the top fan is RF-2750-44 and the number for the bottom fan is RF-2750-45.
Based on other posts on this site and other sites it seems that the upper fan dies on this particular model quite a bit.
Andrew
7helpful
2answers
Haier wine cellar HVTS18DABB top zone won't cool.
Maybe not the answer for everyone, but I proved it was the fan by removing the back panel, removing the fan and finger guard, then placing a small desktop fan that was the same size as the top-rear fan on the wine fridge. Pumping air directly over the heat sink allowed the unit to attain the temperature set on the front panel. The old fan would either not turn at all, or too slowly to be effective. These fans are junk. Especially after finding articles such as this out in different forums for the same issue. I have the HVTS18DABB model unit and the replacement fan is a simple 120mm square, 25mm deep 12V DC fan. Similar or the same as you see in computer chassis. Found some inexpensive, high CFM, low noise fans from the following site:
http://www.sidewindercomputers.com
Specific fan for my application was the model SY1225SL12SH. Although I did order a second fan that is similar in case the .5amps was too high and I popped a fuse. These fans are inexpensive folks, as long as you aren't afraid to get your hands dirty. Good luck.
http://www.sidewindercomputers.com/sc12slsy110c.html
Here are the details on my order:
Name Code Qty Each Options
Yate Loon 120x25mm D12SH-12 1 5.99
D12SH-12 High Speed -
Black (88 CFM, 40 dBA)
Scythe 120x25mm SY1225SL12SH 1 7.95 Add Black Sleeving = No
SlipStream SY1225SL12SH -
110 CFM
Subtotal 13.94
Shipping 7.02
Tax 0.00
2helpful
2answers
Haier hvw18bss wont turn on
Sorry but its just trash, I've been trying to fix mine for over a year now. I have been to countless web sites and payed lots of money for worthless advice. Everyone keeps telling me to check the compressor. HEY news flash it a thermo electric peltier cooler... NO COMPRESSOR. It makes a nice wine rack though...
Wine cooler haire hvw18bss - no power/ will not run
hi geneglass,no rest ,they are built into unit.first fin thermostat and put the two wires together[unit unplug first]then when to gether plug in.the thermo controls run time.if not doing it will need volt meter to check at compresor relay.please help with my ratings if i have been helpful.god bless you,tom
2answers
HAIER WINE COOLER HVW18bss I have this wine cooler and is not cooling anymore I wonder what type of termoelectric module this cooler has and If its worth the fix
GO TO THE LOWER BACK OF COOLER PUT YOUR HAND ON THE COMPRESSORTO SEE IF IT IS RUNNING ,BR CAREFULL IT MIGHT BE HOT,LET ME KNOW AND WE'LL GO FROM THER,MIIKE
Top Haier Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Haier Kitchen Range Expert? Answer questions, earn points and help others
