Birds Logo
A
Anonymous Posted on May 29, 2014
Bird identification by color
What kind of bird has red head, red under belly and grey back?
Kardoc
Level 3:
Top Expert:
  • Birds Master 7,503 Answers
  • Posted on May 10, 2019
Kardoc
Birds Master
Level 3:
Top Expert:
Answers
7503
Questions
0
Helped
2760053
Points
58323
No humming birds the kind that fly arround no moterized in texas
Hello, Mary -
You can find a recipe for making nectar to put in a humming bird feeder on the Hummingbird Society web site:
https://www.hummingbirdsociety.org/feeding-hummingbirds/
The information states "No red food coloring!"
Best wishes.
Apr 21, 2018 • Birds
A black head small Australian bird with a white patch on both sides of its head with a red beak
check the bird identification pictures but it sould like a black head finch
2answers
I have a 2013 keystone cougar 327res and the belly pan is full of water...where should i look for my leak?
This is not just for your camper, but general troubleshooting.
Drain the water from the belly pan. Hook up water supply to shore water source. With water source turned on, allow some time, 1-4 hours, and check if water has returned to belly pan. If water is present then the problem is with the fresh water system. If no water, either it is a small/slow leak or the problem is not with the fresh water system. Next test the grey water tank by pouring some red food color into the shower or sink drain. Flush it into tank with water. Again, wait for some time, maybe over night, and then check for red water in the belly pan. It may take longer for the leak to appear as the grey water tank does not have pressure. If no water, check the black water tank with green food coloring and same technique. If there is colored water, red or green, in the belly pan, then the leak is with associated with the grey or black water tanks. If no water is present after these tests, then the leak may be very small and it may take days or weeks to have water re-appear. In any event, clear water is fresh water system, red water is grey water system, and green water is black water system. With any of them, checking the tanks themselves and all pipes and connectors to/from should find the leak source. The last possibility is that water is entering the belly pan from a roof or vent leak. Check to see if water returns to belly pan after a good rain. If so, the water may be clear or slightly dirty. If it is a roof leak, I have found the best repair is to use Peel and Seal roll roofing It is light weight laminated aluminum and self sticking. Cutting and applying narrow strips 4-6" wide, will seal any caulked area. It costs $95 (3' x 33') at Lowes. A 30" motor home can be completely covered with three (3) rolls, in half a day. I have re-topped 5 motor homes (one 7 years ago) and no more leaks on any of them. The product was developed to seal the roofing joints of mobile homes. Topping should last 15+ years.
I am trying to find out what kind of birds are coming to my feeder ,so I can buy the corrtect food for them.
lots of books world wide
on" local area bird identification "with pictures
librarys ,google images ,
"whats that bird " for example
RSPB What that Bird
Type this description into google and see what comes up.
Jan 18, 2014 • Birds
2answers
Is there a bird that is all red except for the white breast?
Jan 04, 2014 • Birds
4helpful
Bird identification pictures
Robin size bird of soft grey with almost red beak.
Paint number/code for Kawasaki ZZR 600 E 1998 on an S plate.
Everyone you talk to is going to tell you to goto colorrite.com and from what I could find the Ameranth Red Mica is the only color I could find also...that bike does have a base coat however, "1565" and they say "IMPORTANT NOTE: To ensure proper color matching, some of the colors require a base color. If your color does, it will be listed under "ColorRite Base"."
Hope this is what you were looking for
Top Birds Experts
Kardoc
Muhammad Tanveer
Ezekiel mbondo
Ezekiel mbondo
Are you a Bird Expert? Answer questions, earn points and help others
