All toners are good. also with out connecting it to my computer is the a way i can print out a test sheet or configuration report ?
Check the transfer belt and roller
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Minolta 2300DL feed problem
I have the same problem. Which solenoid needs to be replaced, SL-5, SL-7, SL-9, SL-20 or SL-36 (info from pdf service manual).
SOURCE: bizhub C 250 stops printing! Hepl please!
Sounds like the controller has crashed.
If you have a Fiery, reboot it and see what happens.
If that does not help you better call a Technician as it may need to be reloaded.
SOURCE: Double-sided copy output
In print dialogue box there will be a setting for long or short edge binding, associated with duplex printing. Find it and try it. Good Luck.
SOURCE: konica bizhub 7272 imprint is too light
First I would try fresh paper from an unopened ****. You could have moisture in the paper.
Some toners have a tape that has to be removed from the toner before installing into the machine. On the 7272 series machine there was a problem with the gears on the back of the developing unit wearing out and not adding toner. The machine would have made a loud grinding/gear skipping noise prior to failure. If this occurred the seals on the developer unit have gone bad leaking developer into the gears and ruining them. The developer and the developer unit will have to be replace.
Another possibility is the Transfer corona wire has broken or is dirty. Open the two front doors, lower the center lever and pull out the transport unit. A little the the left of center you will see some black paper guides, and under those guides are two channels. There should be two hair thin wires in one channel and one wire in the other channel. The single wire is the transfer wire. Make sure it is clean and not broken.
SOURCE: I have the bizhub C352 - I want to print the
to print meter readings perform these steps. 1-press "utility/counter" 2-press "details" 3-now at the left side of the screen you will see a "print" button, press it and get your copy.
