Heating & Cooling Logo
A
Anonymous Posted on May 29, 2014
What is the ahri# for goodman air model gsc130301EB
Nothing is wrong I just need it for a cool energy rebate
Vongrayson
Level 1:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 25 Answers
  • Posted on Oct 15, 2019
Vongrayson
Contributor
Level 1:
Greenhorn:
Cheetah:
Answers
25
Questions
0
Helped
14487
Points
32
It is rated at a 12
1 Related Answer
pmeneide
JP Meneide
  • 483 Answers
  • Posted on Jun 21, 2015
SOURCE: I have a Hampton Bay AC. It is 18,000 BTU. It is 230 volts. The EER is 9.7 and it is 8.3 to 9 amps. When I use energy mode on the AC it blows warm air. What gives? Just cool mode and it blows cool.
Hi Paul,
  • Energy Saver Mode most likely shutdown the compressor and Fan Only will be running to recirculate Ambient air into the room.
  • Make sure there is no Port or Vent that is open on your unit and would let hot air from outside be mixed in with the ambient air especially if it is hot outside.
  • Also refer to the troubleshooting section of your owner's manual.
Good Luck,
JP
1helpful
My goodman furnace has a red blinking light 6 times and it wont turn off
Voltage polarity switch.
When the light is blinking six times rapidly, this means the power volt polarity has gotten switched.
How to Troubleshoot a Goodman Furnace With Six Flashes
Videos as well
https://www.google.com/search?q=goodman+furnace+red+light+blinking+6+times
I just bought a new furnace and attempting to file for a rebate from the gas company. The form asks for a AHRI Certified Ref#. Where would I find this number?
probably on the specification decal attached to the unit
it could also be the form to say that it was installed according to local regulations and manufacturers specifications
if you cannot find it , ring the person who did the installing
1helpful
2answers
I HAVE A GOODMAN PACKAGED AIR CONDITIONER M/N PCO30-1 B REV. E C/W 9.8 K.W. ELECTRIC HEATER INSTALLED IN A MOBILE HOME. WHAT WOULD YOU RECOMMEND FOR A BLOWER FAN SPEED? CURRENTLY IT IS SET ON HIGH SPEED...
Many have sepaarate speeds for heating and cooling....check it out there should be a heat relay and a cool relay and the motor taps are hooked to each so maybe you can just do a bit of switching wires.....
But, really you probably will have plenty of air flow for the cooling side also if your running that low of a differential on the heating side...
Try it out the worst that can happen is that you will freeze up on the cooling and then you can just switch it back...
heatman101
We have this unit installed this summer we were just looking for the Energy Efficient number, we can't find it for the tax rebate.
You will need model and serial numbers and price of equiptment and Installation. You can locate these on the nameplate tag on the outdoor unit.
Blows out cold air at times
In their effort to try to boost the efficiency of the heating units the fan sometimes runs even when the air will feel really cool...
The fan may start up before the heat exchanger is warm and may run after the heat exchanger has cooled off...
Probably nothing wrong... just the way it is...
heatman101
I am looking for how many tons of cooling my goodman condensor provides
  • Here's the data you requested:
  • Goodman CKL42AR42 Split System Air Conditioner
  • Type: Split System
  • Cooling Capacity: 40000 BTU/hr (3.3 tons)
  • Energy Efficiency Rating: 9 EER
If installing a GSC140481 condensor with a ARUF486016 air handler is it necessary to change the txv to increase energy efficiency? Can these 2 units acheive a 14 SEER rating?
The real question is, am I going to get 14 seer using the old coil with the new condencer.If it is using r-22 then the old txv should work,but the old coil is proboby rated at 10 seer . since these were never tested together you would probobly see a minimal gain in efficency.Now if it is a matched set(ahri rated) you with definently get you 14 seer.Hope that helps!
1helpful
I have a 23 year old Goodman 4 ton HVAC system that has done well but is needing more repairs more frequently. I am looking to replace the unit but anything I install will be placed on credit which is not...
A 23 year old unit will be a major energy hog.You will see a massive improvement even with a less efficient unit,but go with the energy efficiency.The price of fuel is going to keep going up,and you will be using the furnace for many years.I'm in Ohio,and we get by just fine on electric for the very rare occasion the temperature drops below the level where the heat pump cant keep up.If this really worries you,you can put a couple space heaters back for emergency.Of course your talking about a gas unit,or a dual fuel unit.The dual fuel would be your best bet of course for ultimate fuel efficiency,but they can be pricey for the ones with all the bells,and whistles.Some will even use the fuel that is less expensive at any given time throughout the day.For example in some circumstances electricity is more expensive during the day then at night.Ultimately you have to figure out how much energy you use on average to heat your house.If you know the efficiency of the unit you have now you can estimate the actual output energy that is actually needed to heat/cool your house.Which would be the effective output of the old unit.Figure out how much less energy input you will need with a more efficient unit to get the same average output as the old unit.Subtract the energy usage for the new unit from the average energy use from the last winter.This will be your approximate energy savings.This should give you some Idea of the energy savings.
Top Goodman Heating & Cooling Experts
Paul Carew
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
