Maytag PAV2300 Top Load Washer Logo
A
Anonymous Posted on May 26, 2014
HOW TO DISENGAGE THE LID LOCK OF A MAYTAG WASHER
HOW DO I DISENGAGE THE LID LOCK?
1 Related Answer
Anonymous
  • Posted on Aug 06, 2012
SOURCE: want to disengage lid lock on maytag centennial
I had the same problem. The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
I need the repair manual for the Maytag commercial technology top load washing machine
No model number, so generic answers
https://www.manualslib.com/manual/913203/Maytag-Washer.html
The F5 E2 alert indicates the washer can't engage the lid lock because there may be an obstruction in the lid lock area. Please check the lid lock area and remove any objects in that area.
Jun 22, 2021
F5 E2 Error code for top load washers - Product Help ' Maytag
https://www.google.com/search?q=maytag+commercial+technology+top+load+washing+machine+f5+error+code
2answers
Have a new maytag centennial washer and I tried to disengage lid lock by crossing blue and white wires it won't run at all now
why? put them back where they belong. the lid lock is a mandated safety feature on all washing machines. My wife does not like her's either, but has learned to live with it. You may have caused damage to control board by doing that. You have to call for service.
Lid lock broken can I overide?
Washer not starting Cycle:
I would have to slam the washer lid before the washer recognized the lid was shut.
What I did to fix:
1. Ref the link below for Schematics
http://blog.kennyluong.com/Tricking-A-Maytag-Bravos-Washer/
2. Looking at the Lid Lock section of the Schematic:
Place a jumper between pins 2 and 3 of J15
This engages the 1st switch (Lid Lock) so, I don't have to slam the lid anymore
3. Since my Lock switch (2nd switch), which is engaged with a magnetic, is working, my work is done.
If you find that your machine is still not starting the cycle, you will need to
replace the Lid Lock mechanism or ref the above link for temp bypass.
2helpful
2answers
Maytag bravos x lid lock overide or bypass
What I did to fix:
This engages the 1st switch (Lid switch) so, I don't have to slam the lid anymore
If you find that your machine is still not starting the cycle after jumpering pins 2 and 3, you will need to replace the Lid Lock mechanism or ref the above link for temp bypass.
2answers
Lid lock button is flashing and wont unlock
I u unplugged the machine and it stopped blinking, the lid unlocked but when I tried starting it again the same thing happened. I cleaned the contacts on the lock but that did not help.
16helpful
3answers
Want to disengage lid lock on maytag centennial
GOOD LUCK
I have a Maytag top load high efficiency low water washer and the lid lock is locked and will not open. I was doing a load of clothes and power went off for just a minute and now I can not get the lid to...
This is a common problem with a momentary power failure, the controller doesn't get time to reset and return to an idle state before the machine gets power back and it gets "confused". You will almost certainly find that unplugging from the mains (Not just powering off on the button, as some door locks have a sneak circuit, even when the power is turned off at the button) and leaving the machine undisturbed for a full 20 minutes will allow a reset, the door lock will disengage and all will be well when you power back up.
Maytag neptune tl code od
You have lost signaling from the Left Hand Lock. The washer has not see the lid go open thru the signaling with the magnetic reed relay in the Left Hand Lid Lock.
See if this post will help you Left Hand Lid Lock Troubleshooting
The p/n for the Left Hand Lid Lock is 25001048
Some other handy links. The Service Manual for reference. Sears Parts Direct for reference..........Rich
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
