Texas Instruments TI-84 Plus Calculator Logo
P
Paul Archer Posted on May 26, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why are Negative exponents creating syntax error where as positive exponents work fine.
Example: 1-(1+.01)^36 = -.43077 But 1-(1+.01)^-36 gives a syntax error.
Stevan Milanovic
Level 2:
Sergeant:
  • Texas Instru... Expert 267 Answers
  • Posted on May 27, 2014
Stevan Milanovic
Level 2:
Sergeant:
Answers
267
Questions
Helped
221518
Points
795
See captured image below. You have to use (-) sign
Why are  Negative exponents creating syntax error  - e79d4f2c-70e5-4b6e-91e0-75f65d5d305a.jpg
Jack Blacks
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 26, 2014
Jack Blacks
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
8812
Points
6
The negative sign you are using is for substraction, when you want to create a negative number, use the negatve sign button that is in brackets.
Hi, I have a Casio fx 991 ex classwiz and for my chemistry homework I have to work with it pretty often. The error comes up when I try to do 1x 10^7.2 (example, the elevated number is a decimal one) and it...
The "syntax error" message that you are seeing on your Casio fx-991EX ClassWiz calculator is likely caused by the fact that the calculator does not support the use of decimal values in the exponent. The calculator can only accept integers (whole numbers) as exponents.
To work around this issue, you can try rounding the decimal value of the exponent to the nearest whole number. For example, if you need to calculate 1x10^7.2, you can round the exponent to 8 and calculate 1x10^8 instead. This will give you a close approximation of the desired result.
Alternatively, you can use a different calculator or software that does support the use of decimal values in the exponent. This will allow you to calculate the value more accurately.
2helpful
Decimal exponents don't work
The EE (or x10^x on Casios) does give a syntax error if you use it with decimal exponents, but the expressions do calculate correctly if you use the full expression with the general power key. The EE key is a shortcut and may have been designed to accept only integer values for the exponents.
I tried that on Casio and the TI calculators.
1helpful
I have a TI-84. It gives me a syntax error when I try to enter problems with negative exponents.
Use the (-) key (just to the right of the decimal point key) instead of the - key when entering a negative number (not just exponents).
- is used to subtract one value from another. (-) is used to negate a value. - operates on two numbers, (-) operates on one.
2helpful
I need to use the exponential function with a negative exponent on my TI-30XIIS. I hit 2nd then e^x button, but when i input a negative exponent I get an error. Help please!
I think what you did was use the minus sign instead of the negative sign, on that calculator, the two are not interchangeable. I purposely used the minus sign just now and also got a syntax error, but it looks like it works with the negative sign (-) located under the 3 button.
1helpful
How do I do e^(0.2)? When I enter e^(0.2) I get Syn ERROR.
  1. Press [2nd][LN] to activate the exponential function.
  2. Type in the exponent 0.2
  3. Press [EXE]
[2nd][LN]0.2[EXE] Result is 1.221452758
DO NOT PRESS [^] : this is the source of the syntax error.
You can put the exponent in parentheses.
If exponent is negative, press the change sign key (-) right after the e appears on screen.
[2nd][LN][(-)]0.2 [EXE] gives 0.8187307531
12helpful
TI-30XS How to enter negative exponents
I'm assuming the lack of a response means using the proper key did the trick.
9helpful
3answers
How to use negative exponents on a calculator?
Uh yes it will allow you to enter a negative exponent.... press the numbers you want then hit EXP button, then hit the +/- button and then the exponent. 60 % of the time, it works...... everytime.
6helpful
Error:syntax when I try to graph
I am no seer, nor will I try to guess what may have happened. This error may come from various conditions
1. The most common reason is an omitted right parenthesis. For instance you press the [sin] function key. It shows as sin( , notice the right parenthesis. You enter the variable, say X, and you press [ENTER]. The calculator gives you a syntax error: It does not know what to do as long as you do not insert the closing parenthesis.
2. Another common source of this error message is the use of the regular MINUS sign instead of the (-). The latter appears on the scren as a smaller, raised minus sign. This is especially true when you want to raise a number or a variable to a negative exponent.
Every function has one way it takes in its food (argument). If you don't do it the right way, it gives you an error. The nice thing is that the calculator gives you the opportunity to correct the error. Whenever you see Error 1:quit 2: Go to, choose GO TO because the calculator shows you exactly the symbol that is creating havoc: It will be highlighted.
Hope it helps.
Poisson
Hello
To raise a number to any power you use the [^] caret key or on some calculators the [x^y] (x raised to exponent y)
20^(4) =160000
20 to the power of negative 3
20[^] 3 [(-) or +/-] ENTER gives 1.25x10^(-4) = 0.000125 (-) is the small minus sign.
If that gives you a syntax error
20[^] [(-) or +/-] 3[ENTER] = 0.000125
27 [^] (1/3] represents the cube root of 27 which is 3.
Hope it helps.
1helpful
Casio calculator fc-100v, to the power of?
Hello
To calculate a number to an arbitrary power you use the button labeled ^ .
If you want the cube of 2 your enter
[2][^][3] will give you 8. If your exponent is negative use the sign change key (-) and close the negative exponent between parentheses : for exemple the sequence to compute 2 to power of negative 5 is as follows
2[^] [(] 5 [(-)] [)] which means you enter the value of the exponent before the change sign (-). If you use the big MINUS sign you will get a syntax error.
Hope it helps.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
