Konica Minolta PagePro 1350W Laser Printer Logo
A
Anonymous Posted on May 25, 2014
Pressure spring 1350 konica-minolta - Konica Minolta PagePro 1350W Laser Printer
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Dec 28, 2015
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1913958
Points
11960
You need to provide more info
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5 Related Answers
KIAAAL
  • Posted on Sep 15, 2009
SOURCE: Konica Minolta 1350 printer won't print with Vista
Also try turning spooler OFF/ON. Also, try turning 1350 OFF/ON. Those sometimes work. But 1350 had same problem with W98SE so must be a problem in 1350 software(?). I got so tired of this that I bought a Canon MFC which works perfectly. Still use 1350 to use up the toner.
Mark Gough
  • 415 Answers
  • Posted on Nov 19, 2009
SOURCE: I need to install my Konica minolta Pagepro 1350
follow the link
http://onyxftp.mykonicaminolta.com/download/Search.aspx
select desktop printers
pagepro 1350w
drivers
operating system optional
Anonymous
  • 35 Answers
  • Posted on Feb 16, 2010
SOURCE: Konica Minolta Pagepro 1350 page count or Print Config sheet?
please go printer utilty option on your pc then you can print a testpage
Anonymous
  • Posted on Jul 21, 2010
SOURCE: Konica Minolta Page Pro 1350 -if I'm printing a
Try makeing one page a doc.
Salim Baig
Saleem Baig
  • 283 Answers
  • Posted on Jul 24, 2011
SOURCE: How do I clean the charge wire on Konica Minolta
Hi
You can find this wire on the front side of the drum assy. You can check near the drum it is known as Corona wire which passes high voltage to erase the drum making it ready to receive the next image. You can clean if with a ear swab without any cleaning liquids. And also do remember that sometimes there is an Blue color tab on right or left side of the toner which moves hence you can clean with it as well. Its been given for the same purpose.
Konica minolta pressure spring
Which pressure spring part number would be a start, location in the machine?
Konica minolta pagepro 1350 en driver
http://www.konicadriver.com/konica-minolta-pagepro-1350w-driver/
Sc45-03 on konica minolta color copier
Sir/mam,
Open the middle section of the machine then open the section containing the drums and Transfer belt. Then look inside the machine from the right side to the left side of the machine there is a assy. that monitors the belt it has three monitors (sensors) that watch the belt DO NOT PUT ANY PRESSURE ON THE 4 SHAFTS YOU WILL DO A LOT MORE DAMAGE!!!!!!!!!!!!!!!!!!!!!!!
If you take a flash light (do not shine on the drums) there are three covers for each sensor on the assy. that monitors the transfer belt if you raise the three covers gentle (DO NOT PUT ANY PRESSURE ON THE FOUR SHAFTS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!) AGAIN!!!! You have to a careful. Raise each cover (Be careful each cover has a spring!!! Clean them with rag (NO LIQUID) also ensure that assy. is plugged in. RECOMMEND A TECHNICIAN.
My Konica Minolta Printer cuts paper
You most likely have a "claw" out of place in the fusing section. These are sharp little spring guided teeth that keep the paper off of the heated roller. If you had a paper jam and pulled the paper out forcefully it can flip these claws out of place, causing it to cut your paper. (or jam more often). To find these claws, follow the heat. They rest on the hottest part of the pressure rollers of the fuser.
I may have a piece of paper stuck in the innards of the Konica minolta 1350
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
