Display is showing fully on front, but no ice and water will dispense. Light will not come on
SOURCE: Asterisk symbol Bosch Refrigerator B20CS50SNS
It means it is time to change the water filter. You can hold the button down for a while and it will reset whether you change the filter or not.
SOURCE: Bosch B22CS80SNS sxs with no lights
You can get the manual here. on page 16 it tells you how to take off savagemode.
Sabbatical mode settings:
– Accoustic signal is switched off.
– Super cool or Super freezing
functions are ended (if activated).
– The interior illumination is
switched off.
– The light on the display panel is
reduced to basic lighting.
– Buttons are locked (except
“options” and “+” buttons).
Switching on and off:
̨ Simultaneously press “options”
and “+” buttons for 5 seconds
When switched on, [Sabbath] is
indicated on the display panel.
Good Luck
SOURCE: on a new (2 months old) Bosch refrigerator
this is probably a burnt out water solenoid, id suggest contacting the place you purchased it from and see if you have warranty, a warranty agent will be able to fix this problem. if not you may have to call a refrigeration mechanic... a long shot would be to check that your water tap is on ( the one that feeds your fridge.. its probably behind or above your fridge.. perhaps in a cupboard next to it.
SOURCE: How do I unlock the ice-maker panel?
Press the lock again to unlock. If the second padlock is on, press and hold for 3 seconds to unlock the child lock.
SOURCE: Just installed a new Bosch fridge, ice dispenser
Make sure it has water on the container and no obstruction on the water dispenser. Try several times. Since it was new unit, sometimes water has not yet completely fill the dispenser tubing hence it will not dispense water.
Look for some carton, foam or plastic obstruction around the dispenser, it may cause hindrance of not flowing water from dispenser into the glass.
Thanks for asking.
