STAT is the mode where you can do all your statistics functions. To change between Normal and STAT mode you need to press the MODE button (just below ON) and choose 0 for Normal.
Clear the statistics registers with 2nd [CSR]. Add the data points with Sigma+. Errors can be corrected with 2nd [Sigma-]. Calculate the mean with 2nd [xbar].
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
You're trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
If this isn't the case, please respond to this post specifying what you're trying to do when you get this error.
turn the breaker to the indoor unit off and then back on....if you have an after market programable t-stat get rid of it they tend to give problems....but they are great when operating properly?
I had this problem. What fixed it for me was clearing all of the lists in the Statistics application and also in the stat app in the f2 pulldown menu select Plotsoff. After that it worked fine
