Apex Digital AT1308 13" TV Logo
Posted on Feb 07, 2018
RCA DTA800B1 coverter box & LXI 13" TV - need remote code
I have the RCA converter boc attached to my LXI 13" TV. I have tried all the remore program codes sugested in the converter box manual but none work to allow the RCA converter box remote to operate the LXI TV.
Does anyone know what the correct code should be?
RS
1 Related Answer
Anonymous
  • Posted on Jun 17, 2009
SOURCE: Need Program Code!!!
the code is just 0000. It worked for me.
I need the codes for sanyo tv to program dta800b1 digital tv converter box remote model is rc27a
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
I have an RCA TV converter box, model DTA800B1. I don't have the box or instructions, I am attempting to conneect it to an RCA TV with a built-in DVD player. I would appreciate the code that the TV...
There are a lot of possible RCA TV codes programmed into the DTA800B1 remote.
Try the following three digit codes: RCA 000, 001, 005, 072, 073, 074, 075, 076, 077, 078, 135,
138, 140, 144, 150, 156, 159, 162, 163, 169, 171, 178, 229, 246, 249, 260, 274, 275, 293, 302 in order.
To program the remote. Turn on your TV manually and press PGM (to the left of the zero in the number pad section). The LED should light and stay lit. Type in the first 3 digit code and press OK (in the center of the arrow keys near the top). See if the gray volume up/down keys work to change the volume. If it doesn't work press PGM again and enter the next code.
Note that the converter box remote will only turn on and off, switch the input from Channel 3 or 4 to AV in, adjust the volume and mute the TV. It will not control any of the DVD functions. Your original TV remote will not control the converter box.
The manual for the DTA800B1 is available here: http://www.1800customersupport.com/productdocuments/DTA800B1_RCA.pdf .
I hope this helps.
(who has the DTA800A which is the model without the analog pass-through.)
2helpful
I bought the DTA800B1 converter box and I tried to program it to my tv but none of the codes you have listed work on my tv I have a emerson EWF2004A. Any more I could try???
Depending on what model rca remote control you have. Here is a link once you find the remote control model number - http://rcaaudiovideo.com/remotecodefinder/?sku=&productType=TV
Have an rca digital converter box model dta800b1 and a phillips universal remote can i program it so my box get the channels
Find the user guide for your universal remote and use the RCA cable tv/satellite codes, and one should work for your RCA DTA800B1 converter box. My Sharp Aquos remote liked the RCA satellite code.
1helpful
Lost codes for RCA DTA800B1 converter box
rca converter box syvania tv codes please thank you robert
Top Apex Digital Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
