Hi Helen,
Push the reciprocating head protecting your hand with a glove if necessary. All the way to a center point just above the shoe or table of the tool. Then loosen the two fasteners that bind the blade keep horizontally from the spool head. An Allen head is a six sided wrench. Where a Torque style is a star style. Either equivalent in a T-handled wrench works best. On to removal.
Support the spool head from shifting around with one hand whilst torqueing the fastener counter clockwise to remove or loosen it to free the blade. Should the blade be seized or jammed in the well of the spool head. Use a pair of needle nose plyers to free the blade by vigorously shaking then pulling.
All of this should be done with the electrical plug removed from power to protect your safety. For me. Safety glasses should always be worn.
Performance Power Pendulum Jigsaw 550W PJS550 customer reviews product...
May all your projects be prosperous. Fare. Well.
SOURCE: jig saw model 7580 type 4, replacement for blade clamp
There is no model 7580 Jigsaw. The only model close to that I can see would be the 7588 Type 4. Unfortunately that part is unavailable for this model. You may want to contact your local Dewalt service center and see if there is a substitute for that part.
SOURCE: How do I change the blade on a Black & Decker
Go to Dewaltservicenet.com and type in your model number and you can download the instruction manual for this tool with detailed instructions on how to change the blade. It is 8 pages long.
on most newer jigsaws there should be a collar that you just slide back to remove old blade and insert new one
Where the blade enters the holder there is a lever to the left(looking face on) pull up on that and it releases the blade.
