I have bought a digital receiver which only has scart, Composit and hdmi outputs. I got a hdmi to Composite converter and connected to my fujitsu plasma but there is no signal to the screen.
SOURCE: ref fujitsu siemens amilo pro v2040 problen
You will then need to repair windows, ensure your cd drive is set as first boot device in bios and insert windows cd and press 'R' for repair instead of install when all the setup files have loaded.
SOURCE: My fujitsu siemens desktop will not start up. All
Try resetting the system BIOS for the MB. Usually a jumper on the MB that clears CMOS and puts it back to the defaults. Does this have onboard video or a seperate card?
SOURCE: Fujitsu Siemens Black Screen problem
Hold the power button in for a few seconds, until it powers off. When it reboots, change your power settings. Don't shut the monitor off after any time span, it isn't necessary.
SOURCE: 'USB device not recognised
Hi Peter,
Try this solution. Just follow this step to uninstall and reinstall the USB drivers. I am assuming that you have a Windows OS.
1. click START
2. right click My Computer (an icon of this can also be seen on the desktop)
3. left click Manage
4. Computer Management will appear
5. look for Device Manager and click it
6. on the right panel, you will see Universal Serial Bus controllers
7. expand that by click the plus (+) sign next to that
8. delete everything under that by highlighting each one of it, then on the keyboard, just press delete
9. once finish with everything, just reboot the computer
Let me know if this works.
Jon
SOURCE: Vertical lines on screen on Fujitsu N6010, not
If no lines via monitor then the lcd is going bad. Only way to fix it is to replace the lcd. SOMETIMES it's a bad lcd video cable but it's rare.
