SOURCE: wf860
with my wt965a hotpoint ultima lcd fault code f 18 it was a reverse polarity on the main electric board of the house which means live & neutral are the wrong way round good luk dekka2
SOURCE: Bosh Washing Machine F18 fault
I also had this problem - the machine was full of water and it flashed up F18. I had to drain the water out of the machine using the small pipe located next to the drain filter. There was loads of water to drain out. I used my oven roasting tray which was perfect for the job. Then I undid the screwcap filter. There was a lot of really black water that came out, along with about two pounds worth of coins and some hairgrips. Now my machine works perfectly !
SOURCE: washing machine wont rinse or
I just fixed my machine through this site, it means the drainage hose is blocked.
The small access door at the front has a hose and a small screw cap. I drained the water via the hose then undone the screw cap and found it was blocked by tissue.
Put everything back and now is working.
SOURCE: my bosch classixx 6, 1200 express washing machine keeps displayin
Bosch classixx 1200 express washing machine won't drain
