Mine had the same noise from the time I bought it, and since none of the answers I have found anywhere have been helpful, I tore into it yesterday and I narrowed it down to the plastic tension wheel on the belt. I was able to completely eliminate it by taking it off, knocking the bearings out, removing the small spacer between the bearings, and reassembling it. Noise is gone and it works great now.
Chain too tight or not lined up correctly. Readjust the rear wheel.
SOURCE: My Schwinn hybrid bike makes a popping noise in
Your pedal berrings are going out try replacing it.
SOURCE: schwinn 201 recumbent bike makes clicking noise
Check the tightness of the crank bearings, also the crank fastening nuts (on axle) If its the gears you may have to turn the screws on the rear derailleur to adjust the tracking. The same as the front. Your question is kind of vague so its hard to pinpoint the clicking noise. Could even be a stone in the tire??lol
SOURCE: Bad crank bearings can move crank arms small amount.
clicking can be a stiff link in your chain.
