Suniva OPT 245 Watt Mono Solar Panel Logo
A
Anonymous Posted on May 05, 2014
What is the afis wire on bmw factory amp? - Suniva OPT 245 Watt Mono Solar Panel
Greg Scott
Level 2:
Novelist:
  • Expert 116 Answers
  • Posted on May 12, 2018
Greg Scott
Expert
Level 2:
Novelist:
Answers
116
Questions
Helped
41054
Points
377
That is the connector is to power the amplifier in a 10 speaker system for BMW
Where is the factory amp located ?
In the trunk up next to wheel wells. Start peeling carpet out of the trunk walls and you will find it. The rear speaker wires run right to it.
Please beware that only the 10 speaker systems have a factory amp. The stock 6 speaker systems run straight off of the factory radio. You can buy a factory amp bypass harness for this model at any good car audio shop.
1helpful
2answers
I have problem with hid light
follow this link to u-tube video not the exact vehicle but the principle will be the same,or search for your exact vehicle
How to replace low beam xenon HID bulbs 2006 BMW 330i
I connected the bmw harness to a new new eonon radio,.There is power but no volume. whats the problem?.
In that vehicle there is a factory amp. It will power up with the White wire in the factory harness. Hook the amp out wire from the aftermarket unit to this white wire. It also controls your antenna.
Need to wire stereo in a bmw e 1983 looking for color codes for b
My Advise is to REWIRE all SPEAKERS SEPERATLY & INDEPENDENT From Factory Wiring, as it is Safer to do this than to INCORPERATE Your Sterio Wiring into the Original Wiring, Some Vehicles Use Spicific Wiring to OTHER Components. I'm Sure this is NOT the Answer you WANT But I have Installed more than I can Countof Stereo Systems into Cars/Trucks ,Tractor trailers and Inicialy I Only Ran Into PROBLEMS When Incorperating into Factory Wiring Thus I Refined MY METHOD By Simply Wiring all EXEPT the BATTERY & IGNITION < Key ON Wires. ONE SLIP In INCORPERATING INTO FACTORY WIRING Can CAUSE SERIOUS PROBLEMS/DAMAGE the ELECTRICAL SYSTEM. I Realize that in MANY Vehicles this CAN and HAS Been DONE But at the Same time When you ISOLATE the NEW STEREO WIRING You KNOW EXACTLY what you Have. As Far as Color Codes they CAN and DO VARY from Year to Year and Makes Also. What I am Recomending May be SLIGHTLY more Expensive and Require Some Time BUT the End Result will be Well Worth it. Thank you for your time !
Factory amp turn on wire for 93 bmw 740i
u would need the factory service manual . find suspected turn n wire and a test light to it while turning on head unit will light up when the right wire is found . ideally a multimeter is better to check this wire for 12 volt or 500 ma of power , just be carefull
3answers
How to install hid on a bmw 325xi 2006
INSTALLATION GUIDE:
BMW E38 99-01 HID TYPE 7 Series 1PC Halo Amber Projector Headlights
Parts Identification:
Projector Headlight
Halo & L.E.D.
Bottom of the Headlight:
Ballast Bracket, Halo Wires(red/black)
Turn Signal Adaptor
TOOLS REQUIRE
10mm - 8mm socket
Philip Screwdriver
Crimper/Pliers
For more information about how to install your vehicle, come visit our youtube page on
http://www.youtube.com/spyderauto
Remove the facotry headlight from the BMW. First remove the front panel cover below the headlight to access the bottom screw of the headlight housing. There is also two screws on the top of the housing.
Once you have remove the headlight, turn the headlight around and remove the bracket that holds the Ballast. Then remove the ballast using a philip screwdriver.
Unplug the wire from the ballast, and then remove the Xenon Plug from the housing. Put the Ballast aside.
Carefully remove the D2S Xenon Bulb from the factory housing. Once you have remove the bulb, transfer the bulb to the Spyder headlights.
Remove the bracket from the Spyder Headlight, and then install the ballast on the housing like the original. Once you have put the ballast on, put the bracket back on.
Remove the Panel Cover bracket from the original headlight to the new Spyder Headlights as shown here.
STEP:
Install the Spyder turn signal socket if the orignal does not fit, unplug the factory plug from the harness and plug the new one on.
Install the Spyder Headlight back on to the vehicle. Plug the Harness back on, the halo/L.E.D. Wires is connect to the Parking lights. These wires are optional to your vehicle, you do not have to wire them together.
Factory Xenon Headlight
Spyder Projector Headlight using Factory Xenon Lights
STEP:
pls vote an diam giving you link also for better help BMW e46 HID Headlight Replace
1helpful
Radio install
website www.modifiedlife.com along the top theres a list of what your looking for
White noise in 745
It sounds like you have a couple wires touching that are not supposed to be. I recommend tracing all the wire from your radio all the way back to the factory amp. If the factory amp is getting power while the vehicle is off then this is what is causing the white noise. I hope this helps, don't hesitate to ask any additional questions and please don't forget to rate me.
Top Suniva Renewable Energy Experts
Florinda Byers
Level 1 Expert
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
Are you a Suniva Renewable Energy Expert? Answer questions, earn points and help others
