Kenmore Elite 45986 Front Load Washer Logo
Posted on Nov 03, 2007
Kenmore washing machine shakes when spinning out
It is a kenmore washner
  • Anonymous May 22, 2008
    I also have this problem. The bearings can be replaced, but it is a very big job (4 or 5 hours). When I took the back apart and removed the pulley, I could see that the bearing was shot (all of the balls where blown out) There is a retaining clip that makes it look like the bearing can be replaced, but i cannot get the outer race off. This is actually made by Fridgidaire and apparently a very common problem. I would not recommend either.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 12, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1320
Points
You should check the floor under the washer. front load washers need to be on a hard surface such as concrete. if it is on a wood floor chances are it will shake.
Anonymous
Level 1:
  • Posted on Nov 04, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1320
Points
Our's did this, it shook horribly. it turns out one (or more) of the shocks had come out and the technician had to come out and replace the shocks.
Engineerguy
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Jun 26, 2008
Engineerguy
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
3170
Points
Mine shakes during the spin cycle. It only shakes at certain frequencies which tells me that there's an eccentric load or a shot bearing. After learnign about the problem, I think I'll just go out and get a new washing machine... but not a Frigidaire/Kenmore rebranded model. Paid $1100 for this 5 1/2 years ago. Expected it to last longer than this. Obviously either the engineers @$% up or the buyer purchased poor quality bearings.
iwannahelp
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Feb 13, 2008
iwannahelp
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
Helped
4715
Points
5
I was told by 3 technicians that my washer had shot bearings and this is a common problem for the Kenmore Elite Front loader.
Sears knows it and it costs $800 to replace the unit with the bearings. They will not do anything about it except try to sell you a new washer.
I will not buy this washer again (especially from Sears).
A
Anonymous
My did this until I had a technician out for the pump and I told him about this problem. Turns out the feet weren't locked in place.
The wasing machine shakes badly when in a spin cycle.\r\n970-C45092-00
Hi
First check if the machine is level .Also makes sure you do not have an unbalanced load. Lint filter between the tubs is loose/broken, tub nut and drive block is worn, bad brake, worn spin tub are some various reasons when washer shakes in spin cycle.
Please check the bellow link to troubleshoot your problem:-
http://www.wikihow.com/Fix-a-Shaking-Washing-Machine
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
1helpful
Front loading machine shakes violently during spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
1helpful
Kenmore Whasher shakes on spin cycle
unfortunetly this is common , these new frontloads spin fast even with no pedestal these things move...
make sure the locking nuts for the legs on the pedestal are screwed securely up to frame on pedestal, also could be a floor issue depending on where it is, slooping or not solid floor.
Kenmore Oasis HE shakes violently during spin cycle
Machine legs should be adjusted so that machine is level and standing on all four legs. The load in the machine should be evenly distributed. Utube has an excellent video on washing machine repair.
1helpful
Shaking in spin cycle and tub moves too easily in washing machine
the tension springs on the tub mite have came loose during moving
Kenmore washer stock no. 22642 shakes terribly during spin cycle
There is a suspension plate under the tub.
It also has 3 pads on it to support the tub.
There are springs attached to support the angle of the tub.
Check all these parts and repair or replace as necessary.
Kenmore front loader washer squeaks in washer mode and shakes in spin.
shocks made of plastic squeaks, a little greese may help
1helpful
2answers
Kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Alexander
vince
