I am left handed and I would like to know if there are any lawn outdoor chairs that have a left handed tray? If so, where can I purchase it. Thank you.
Saa.co.uk sell them. I bought mine from a fishing website several years ago but its made from steel rather than aluminium so is a lot heavier to cart about than normal ones
If you have old lawn chairs with plastic straps/webbing that have become gooey or sticky I found that automotive brake dust cleaner does a great job restoring the plastic to like new. I used Simoniz "Brake Dust Buster". I sprayed it on, went over the surfaces lightly with a soft brush, ( a sponge ought to work as well), and then rinsed it off with a hose. Stickiness gone!
you have a couple of options
contact the manufacturer if the chair for a replacement ray
cruise around second hand shops for a cheap chair to get the tray from
go to a cabinet makers and have a suitable tray made up
or if a metal tray go to a sheet metal shop to make a tray
and lastly find a shop that makes fiber glass items and have them make up a tray
any thing you decide will probably cost more that the chair is worth but prices will be what you decide on
Your version has a Dynamic Controls model controller and joystick. Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand) Turn the chair off, wait 5 seconds, turn the chair back. If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors. 3=Left motor fault 4=Right motor fault 5=Left brake fault (may not be engaged) 6=Right brake fault (may not be engaged) Any other fault code usually means the electronics or wiring is bad and not worth fixing.
The easiest way to do this is to tip the chair forward so that the top of the chair and the arms are on the floor. The weight of the chair will be off the lift frame in this position. Look at the motor and you will see it connected to the frame with 2 hitch pins.
It is easiest to remove the top hitch pin which will now be on the bottom because the chair is upside down. Pull the clip (looks like half of a paper clip) from the pin that goes through the square chair frame and motor round tube. Pull out the pin by lifting the bottom of the motor slightly(now at the top because the chair is upside down)with your left hand and pulling the pin out with your right hand. Find the two nylon washers that have fallen out when you do this.
Swing the motor tube out of the way toward the front of the chair. Hold on to the pin, clip, and 2 nylon washers for re-assembly. Hope this helps.
