Samsung hln617w is giving no signal from all inputs, also is there anyway to update the firmware.
Main pcb approx $72.00 at
http://www.shopjimmy.com/samsung-bp94-00434a-main-analog-board.htm
however thay are out of stock. Be sure this part # is a match to your complete model# B4 trying to order, this site lists the various models this pt# fits.ALSO considering the age, they may not be able to get anymore of these.I recommend calling to confirm.
As for firmware updates, that info can be found at Samsung web site:
http://www.samsung.com/us/support/contact
under product support. you might also check at the Samsung web site for the Main PCB. expect it to be much higher & please have your complete Model & Serial numbers available when you contact anyone.
SOURCE: samsung hlp4667 only get a picture with HD input.
is there anything else hooked up to your tv other than cable or satellite? if no other components (dvd, vhs, etc) then you will get a snowy screen because the other inputs are for other components that are hooked up. a picture is showing on the HD input because you have cables hooked into that input.
SOURCE: Samsung HLN617W DLP 61" TV only show green color
Check your color wheel.(These shatter) Can purchase these at Electrified Discounters
SOURCE: Samsung HLN617W No Sound.
Red light comes on but then the tv is playing but after about 3 hours it just goes out but I can still hear the sound then if I go back after about 4 to 5 hours if I turn it on it plays no problem. Now the lamp just went. I think before replacing the lamp maybe I should replace cooling fan also.
