SOURCE: Need assistence in setting the date and day on my citizen 8700 eco drive
There is an ID number I need to help you further it is the Movement Caliber number probably on the back. Once I have that I can help you further.
Regards,
Worldvet
SOURCE: Citizen Eco-Drive Skyhawk JR 3060-59F
Paste this link into your browser and follow instructions:
http://www.citizenwatch.com/CUK/English/settings_int.asp?caliber=C650&interactive=C650
If this is not the correct caliber number, click on technical support tab in the same webpage and find the right one for your watch.
DO NOT FORGET TO RATE, PLEASE.
SOURCE: Does the Citizen Calibre 2100 have a battery that
Citizen EcoDrive does not have calibre 2100. This is ordinary quartz calibre and uses battery SR-626W. This battery will last for 2 - 3 years and is not rechargeable.
You can check for yourself using this link:
http://www.citizenwatch.com/CUK/English/home.asp
Rate me, please.
SOURCE: I cannot set the date on my Citizen SkyHawk Eco-Drive
Just pull the crown out, turn it so that the bottom analog display is set on "CAL" and push crown back in. Voila!!
SOURCE: daylight saving time
You can get instructions from the Citizen web site.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on "get setting instructions"
