Texas Instruments TI-84 Plus Calculator Logo
A
Anonymous Posted on Apr 26, 2014
How to convert -1.185294e^-4
The homework that I am doing wants a number rounded to the 5th decimal place, I need a real number, not e^-4
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Jun 11, 2009
SOURCE: Default decimal settings
Your BA II PLUS stores numeric values internally to an accuracy of 13 digits. However, the numbers it displays depends on the number of decimal places to which you have it set (choice of 0–9 or floating decimal). To set the number of decimal places displayed to three: hit [2ND][FORMAT][3][ENTER]This setting also continues indefinitely (even though the calculator is turned off and on) until it is changed.
Anonymous
  • 3 Answers
SOURCE: need to program to fifth decimal place
Your BA II PLUS stores numeric values internally to an accuracy of 13 digits. However, the numbers it displays depends on the number of decimal places to which you have it set (choice of 0–9 or floating decimal). To set the number of decimal places displayed to three: hit [2ND][FORMAT][5][ENTER]This setting also continues indefinitely (even though the calculator is turned off and on) until it is changed.
k24674
  • 8093 Answers
  • Posted on Oct 24, 2009
SOURCE: Why can't I change the number of decimal places on
It seems to me that you are omitting a step: see screen capture from manual (step 4). Hope it helps.
Anonymous
  • 11 Answers
  • Posted on Dec 02, 2010
SOURCE: MY TI nspire always rounds
Turn it on, hit MODE then change the FLOAT value from 1 to Float itself. Float allows you to round, and something changed that setting
Anonymous
  • 10 Answers
  • Posted on Mar 05, 2011
SOURCE: My Ti-nspire is set to Float. However, on the box
Float on the t-nspire essentially means round to the nearest whole number. Your best bet is to set float to a higher number.
1" THRU 11" IN DECIMAL
Some of us help with homework, but I cannot understand your data. Does it mean 1" through 11" as a decimal of 12" ?
If so a calculator is all you need, eg 1 / 12 = 0.083
2/12 = 0.167
3/12 = 0.250
4/12 = 0.333
5/12 = 0.417
6/12 = 0.500
7/12 = 0.583
8/12 = 0.667
9/12 = 0.750
10/12 = 0.833
11/12 = 0.917
I have given these answers to 3 decimals, but some are actually rounded off. eg 8/12 = 0.6666666666666666666666 forever.
How to convert fraction to decimals
Hello, let's say you want to change 3/4 to decimal. You take 3 divided by 4 =.750. That is the top number divided by the lower number. Good luck.
How do I convert fractions to decimals on a TI-86 calculator?
Just divide the numerator by the denominator. For example, to convert 1/4 to decimal, press 1 / 4 ENTER and see .25
Rounding decimals 3 places
You round a number with several decimal places to a number with fewer decimal places.
1.14 rounded to 1 decimal place 1.1
What you are asking for can be done by putting a zero after 4 and write 1.140, BUT that is not rounding. In fact you can put as many zeros after 4 as you want.
2helpful
How to I stop my sharp EL-531X calculator from rounding when converting from decimal to scientific notation?
You need to select the number of decimal places you would like, or if you would like the calculator to behave as normal. Press SET UP and select FSE (press 1) . You now have 5 options.
0: FIX means you can choose a fixed number of decimal places for every calculation.
1: SCI means scientific notation and choose the number of significant values you would like to deal with.
2: ENG means engineering and the power goes up in multiples of 3.
3: NORM1 and 4: NORM2 are the usual or normal settings on the calculator. Most school calculations will use NORM1 mode.
1helpful
Explain "CUT", "UP", "5/4"
CUT: Values are cut off to the number of decimal places speicified by the current Decimal Place Selector setting
UP: Values are rounded up to the number of decimal places speicified by the current Decimal Place Selector setting
5/4: Values are rounded off (0,1,2,3,4 are cut off; 5,6,7,8,9 are rounded up) to the number of decimal places speicified by the current Decimal Place Selector setting
3answers
How do I convert decimal to fractions, and fractions to decimal with this unit?
If You Want to Convert Decimal to Fraction for your maths class. These types of calculations are we can learn on 5th to 10th Standards. If you are studying in 5th to 10th class and you don't know how to convert your decimal number to fraction number. You want to learn about decimals and fractions.
https://www-calculator.com/
4helpful
3answers
How to round the fig. in Excel 2007 E.g. 12350*32.75% = 4044.625 I want it to be rounded to nearer rupee. If the decimal is lesser than 50, rounded fig. should be lower Rupee if the decimal is more than 50...
The function is called ROUND. It has 2 arguments, (1) the original number and (2) the number of decimal digits. Here is the Excel's help: ROUND(number,num_digits) The number you want to round. None. num_digits The number of digits to which you want to round number. If num_digits is greater than 0 (zero), then number is rounded to the specified number of decimal places. If num_digits is 0, then number is rounded to the nearest integer. If num_digits is less than 0, then number is rounded to the left of the decimal point.
So for your case use this in a cell "=ROUND(12350*32.75%, 0)" without quotes, where I assume one or both numbers will come from other cells. -Ken
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
