How to Set the Time & Date for a MP25DV Canon Calendar & Clock Printing Calculator
The steps listed in the Calculator Instruction Manual for the Canon MP25DV Calculator did not work. The correct steps for setting the time and date on this calculator are listed below:
1. Press the time/calendar button one to select the date mode. The display should show the month-day-year. 2. Hold down the = button until the month start flashing. 3. Use the number keys to enter the current date, month and year. Example 07-22-2021 4. Press the = key to set the current date. 5. Press the CE/C key to return back to the calculator mode. 6. Press the time/calendar button twice to select the time mode. The display show the hour-minute-seconds & time of day. Example 02-01-14 A 7. Hold down the = button until the hour start flashing. 8. Use the number keys to enter the current time. 9. Press the X button for (A) a.m. or (P) for p.m. 10. Press the = key to set the current time. 11. Press the CE/C key to return back to the calculator mode. 12. To check the current date and time on your calculator, press the calendar/time button once for date and twice for time.
I bet your display is showing the correct ans, however your printer is printing incorrectly. Settings have nothing to do with your ans. You need your printer to be cleaned or have the printer replaced with a rebuilt unit. I can do this... 608-222-2484...
SETTING YOUR TAX RATE
you hold your set % button down for three seconds until set shows again, then hit tax rate button it shows your tax rate, change your tax rate then hit set your tax rate should be set.
cliff notes:
hold set% button
hit tax+ button
change the desired %
hit set done
