Washing Machines Logo
j
jennifer Posted on Apr 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clothes got twisted in the rubber gasket now it wont spin
About 10 peices of clothing got so twisted in the bellow i thought i was going to have to cut them the washer must not have stopped the cycle the rubber is still inplace and i got the wire back on but now it does not wash or spin
tom weber
Level 2:
  • Expert 198 Answers
  • Posted on Apr 23, 2014
tom weber
Expert
Level 2:
Answers
198
Questions
6
Helped
109553
Points
452
Try unplugging machine for ten minutes. Then try again, If nothing happens call for service, may need new control
DR NITIN KHANDELWAL
Level 3:
  • Master 383 Answers
DR NITIN KHANDELWAL
Master
Level 3:
Answers
383
Questions
0
Helped
63812
Points
1101
Contact Authorized Service Center.
Clothes got twisted on front rubber piece put it back together and now the washer does not spin
Did the rubber tare when it got twisted? If not did you remove the rubber below and reinstall it. If not then it may of slipped and could be causing a bind in the drum.
Wbvh5300k2ww washer leaking
door gasket or door boot or the door bellows, it can be referred to by any of these 3 names
I have Kenmore Elite HE3 Front Load Model 110.5862400. The rubber gasket/bellow got wadded up with clothes and popped out along with the clamp. How do I put back together. There is no damage but I don't...
The following link explains the steps required to install a door bellow on a front loader:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Inspect the bellow and the front and rear clamps to ensure they are not damaged. If the bellow has any rips or tears, it must be replaced or it will leak.
If you have any questions, please let me know. I hope this helps you.
NOTE: Overloading the washer can contribute to items getting caught in the bellow and causing premature wear. Follow the manufacturer's recommendations for proper loading.
I have a gltf294oeso that is ruining clothes by
Ive replaced multiple bellows due to this reason...check the inner tub for any extra play first, but bellow should fix problem(bellow is a pain to put on, be prepared to spend an hour or two, or may want to call a service company)bellow part#134365200
2answers
Washer is ripping my clothes
yep, I have that problem too. My son's winter coat got wripped to shreds.
2helpful
Washer will drain but not spin out clothes
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Wash machine noisy during spin cycle and clothes still wet
what did you take off? to remove the pump there are 2 clips. then after removing this there are 2 more clips forget about the screws if you had them. If you had screws one did not fall into the motor did it? Anyway if you had 1/4 inch screws you can toss them. if you removed the clips from the motor and took the motor down did you align the coupler correctly? there is a 3 pronged plastic peice on the motor also there is a 3 pronged plastic peice on the transmission. between the two is a rubber grommit. make sure everything is ligned up. check these things first and let me know.
1helpful
I hear noise but the drum will not spin in spin cycle.
when you spin it by hand dose it feel free or restricted? if rstricted you may have a peice of clothing between the two tubs.if free you can have a worn clutch.but it would agaitate fine.if wont agaitate or spin it may be your drive coupler.and if the drive coupler failed your washer will still drain.if you need more help you can email me thru FixYa God bless ,tom
4answers
Washer Creates holes in clothes
We purchace a washer and dryer in Dec 08 Kenmore HE energy star. They started destroying cloth about 2 months after purchace.
under our warranty and many many calls they sent a new set. 2 months later same problem. HELP
3helpful
4answers
Stains on clothing
Usually black oily stains are a symptom of a rear main drum bearing starting to go bad. The seal goes bad first and the packing grease will start to weep out as water gets into the bearings. Is the washer starting to get loud during any spin cycle? If so, I think your bearing is starting to go. It's not a cheap fix, either. The whole back shell of the outer wash tub has to be replaced because the bearings are molded into the plastic. I hope this is helpful in some way.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
