I am repairing an mms321. To open it you must first remove the silver speaker facing which must be gently pried up as it is glued on to the face. This will expose the phillips screws which must be removed to allow the speaker assembly to be removed from the speaker housing. Once inside there are two mounting screws atop the transformer. These don't have to come out if they are not the cause of the loose parts.
It is glued together, you can pry it, which will break it, attempt to heat up the glue with a heat gun is your best option
