Konica Minolta magicolor 2400 Laser Printer Logo
A
Anonymous Posted on Apr 12, 2014
Head centring problems - Konica Minolta magicolor 2400 Laser Printer
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Jan 09, 2016
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1911963
Points
11959
What head? and what is centering?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
How to remove stock pan head on velbon el carmagne 530 so I can replace it with a ball head?
I presume this is a tripod, although you have not stated. On good quality tripods, the head attached to the centre column with a screw thread, either 1/4" or 3/8". Grasp the centre column firmly, and rotate the existing head anti-clockwise, first checking to ensure there are no grub screws restricting its movement. When you have removed it, attach the replacement.
1helpful
I cannot get my MHXPRO 2 w fluid head off my manfrotto 055 tripod both brand new. I have tried to follow the instructions but without succes
Try removing the centre column, then clamp it securely in a vice (or vise, if you prefer), packed with wooden battens to prevent damage.
Ensure that all the locks on the head are secured tightly. Then rotate the head counter-clockwise, and it should unscrew from the thread at thye top of the centre column.
If it still won't shift, try spraying a little WD40 or other such lubricant at the place where the head attaches to the centre column, leave it to soak in, then try again.
If you still have no luck, hie thee to thy local repair facility and humbly beg assistance from the artificer.
How to remove the head of a Giottos camera tripod
Most tripods have a 1/4" thread attached to the centre column, which then screws into the base of the head (some may have a 3/8" thread, but the principle is the same).
Grasp the head firmly in one hand, the shaft firmly in the other, and rotate the head counter clockwise to remove the old head. If it has been in situ for some time, it may be stiff to rotate.
Once you have removed the old head, lubricate the threads on the centre column, then attach the new head, rotating this one clockwise.
If the old head will not unscrew under firm manual pressure, remove the centre column and place in a vice, packing it with wooden battens to protect it. Then attempt to unscrew the head, using a mole grip or similar if necessary.
1helpful
How do I ajust headlights?
place the vehicle on level floor about 3ft from a blank wall at night. turn on the head lights to high beam. You will see the centre of the light beam s on the wall ,the centre of the beam has to be set just under the centre height of the head lights and slightly off to the passenger side.
adjustment is by 3 screws at the back of the head light fixtures (springs under the screws)
turning these in or out moves the beam centre and by using a combination of screws movements you will achieve the desired position for the beam centre
Hs 360 scooter light flashes 7 times how do i fix the problem
Hi, this is normally because the throttle pot is either not dead centre or related cabling etc to the controller has been damaged. when looking at the throttle lever look at the centre stem, you should see a cross head, now when at rest this should be dead centre to you, if it isn't it means it moved and that's the fault. Now loosing the related holder etc will allow you to centre it again.. Please contact me for more info if required..
Regards
www.gewirepairs.co.uk
1helpful
Ryobi plt-2543y engine runs okay but head will not
Ken it sounds like the shaft isn't going in to the spigot on the engine. Make sure that the head is on properly and that the shaft is in the spigot itself. If there has been any movement with the head creeping down slightly the shaft will no longer go into it. Try and straighten the shaft slightly to give a couple of millimeters more to the shaft.
I need to know torque specks and tighting sequence for a cylinder head on a 19.5 hp briggs and stratton model number 461707 0145 e3
here is web site for manual
http://www.briggsandstratton.com/engines/support/operators-manuals/?NTT=+461707+0145+e3+
from the top of my head 160 in/lb torque setting
pattern gos top centre , botm left,top left , centre right , top right , centre left , centre right then centre left , then botm right
cheers pauly46
May 29, 2011 • Garden
How to scan
start from top  look from left to right until reached centre of book when reached centre return to leftside tilt head down 1degree then repeat until end of page at end of page tilt head back to start position turn head to page on right side and repeat process
Good Morning ,I have a Westherm thermostat fitted to the central heating radiators in my home.I have read the posts concerning freeing the centre pin and understand how to free this.After freeing the...
after removing thermostat head apply minute drop of WD40 to centre pin and move gently replace thermo head and thermostat is working as new.
2helpful
Replacing print head
Lift the top cover when the printer head stops in the centre push the printer head to the right about 5mm. you should then see the tab you need to push to the back of the printer to release the printer head once you push this allow the head return to the centre and then you will be able to lift the printer head out
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
