WE HAVE PLACED IN REGENERATED CARTRIDGE PRINTER EPSON AcuLaser C9100, WE TELL THE ERROR THAT THE CARTRIDGE IS EMPTY. HOW CAN THIS MESSAGE Reset?
THANKS
The waste toner cartridge has a transparent extrusion on the bottom, which fills with toner when the cartridge is full, but also if it is half full and shaken so that toner falls into this extrusion. If this happens, the only way to remove the toner is to open the cartridge by removing the tape, taking the two halves apart and shaking/blowing/hoovering it empty. You can stick them together again with ordinary sellotape.
SOURCE: Epson Aculaser C9100 Colour Laser printer
If you changed the bottle and rebooted the printer with no change, it could be that the sensor for the bottle may be faulty. Try cleaning it:
1. Remove the CASSETTE ASSY.
2. Open the COVER ASSY FRONT.
3. Remove the two screws (silver, flanged, 8mm) that secure the COVER over the sensors. Remove the Snap from the main unit Frame, and remove the sensor COVER.
4. Use a paper towel or cloth to clean the sensor area of any dust or toner
Turn off your Epson C900 printer and unplug it from your computer and from the electrical socket. Open the left-side panel of your C900 printer and locate the toner cartridge you want to replace. Epson has labeled each of the four cartridges.
Stick a finger in each of the holes in the empty toner cartridge. Pinch your fingers together and then slide the cartridge out from the printer's interior.
Remove the new toner cartridge from its packaging and shake it vigorously to remix any settled toner. Take the cover off of the new cartridge by lifting it up and out to the right. Slide the new toner cartridge into the empty slot in your C900 printer. Close the left-side panel of your C900.
