I did as you said and its work now, high five bro u r the best
No such code for a bizhub 350
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: I want cd for instale KONCA MINOLTA PAGEPRO 1300W (driver)
Try this driver (choose the operation system)
http://crm01.konicaminolta.eu/openmind/technic/kmpsdwl.nsf/psearch?OpenForm&ch=PRI&dist=BPE&ui=en&dg=sw&prod=PagePro%201300W&dsg=&os=&lang=&ml=0&rid=41256849005CE173&sub=Printer%20Driver&pcat=B%2FW%20Printer&pcc=1
don't forget to vote!!!
SOURCE: error code c-2833
CAUSE: LD Power becomes saturated when performing Auto Gamma adjustment in a low humidity condition.
SOLUTION: Perform the following adjustment:
1. [Utility].
2. [Machine Admin. Setting].
3. [System Setting].
4. [Expert Adjustment].
5. [Process Adjustment].
6. [Toner Quantity / Exposure].
7. Select the proper Exposure Adjustment [Yellow, Magenta, Cyan, or Black] by using the Next/Previous button.
8. Select Standard then select [-2] under Exposure.
9. Press OK.
Notes:
a. If the problem persists, replace the problem color drum since the cause of the SC is the combination of drum characteristic and humidity.
b. The following codes = colors: C-2831 = Yellow; C-2832 = Magenta; C-2833 = Cyan; C-2834 = Black.
SOURCE: konika minolta bizhub 350 Error c3451
Hi there.
Try this It could do the trick for you.
The error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
I bet it happened when you first switched on one morning.
Easy to reset and fault usually goes away.
To Reset switch machine off using the switch inside the front door, not the one on the control panel.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on.
This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing.
Hope it did work for you.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: trouble code c-3721 on konika minolta multi functional printer
was told this message meant Konica have disabled the machine remotely.
SOURCE: HOW DO I SOLVE ERROR CODE C3451 IN KONIKA MINOLTA
You will need to replace the thermostat and the best solution is to ask a technician to do that.
