LG 440G Black CePhone - TracFone 3G, 1.3 MP Camera Logo
A
Anonymous Posted on Feb 13, 2018
The phone isn't telling me when I get a new text or email. Nor is it vibrating.
In the past few days, whenever I receive an email or text, I no longer get a notification on the home screen. I have to go under messages and email to see if I have received anything new. It doesn't vibrate or if I press the side button it doesn't say if I have received the message either.
MYCT 92
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Feb 13, 2018
MYCT 92
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
510
Points
7
Go into settings go to notification go down to messaging and then go down to email look to see that notification is turn on in messaging and then go to email & c F notification is on in email
5 Related Answers
Anonymous
  • 8 Answers
  • Posted on Jan 26, 2008
SOURCE: Trying to Forward Forwarded Text Messages to Email
Try saving the pictures to your phone first than sending them to your e mail
Anonymous
  • Posted on Nov 12, 2008
SOURCE: Connection problems
what is the master reset for lg vx8500
Anonymous
  • 12 Answers
  • Posted on Feb 13, 2009
SOURCE: On my LG VOYAGER I turn it on to vibrate but it doesnt!
Sounds like the thing that actually vibrates is broken. Take it to verizon tech.
Anonymous
  • 132 Answers
  • Posted on Mar 13, 2009
SOURCE: on the LG KP500 can you get a text alert of an appointment?
Set your appointment through your calendar. It will indicate when you wished to be notified and how long you want to be notified. If your worried about the sound of the alert when you receive your appointment notification, then change the default sound within your settings.
Anonymous
  • Posted on Jul 31, 2009
SOURCE: lg renoir phone - sound issue
You are in the right place but looking at the wrong option, if you scroll down on the Normal profile you will see a message tone option, if you are not hearing a tone at the moment then I suspect it will say "No Sound". Tab this option and select Existing sound, you will then be able to navigate through the sound files on your phone and choose one of the Default Sounds (from the folder by the same name) or an MP3 or other supported sound file you have added to your phone.
If that doesn't solve your problem then you may have a faulty phone.
You can change the sound you get when sound alert is switched on by going to Settings > Touch Settings > Touchscreen Effect and choosing a different sound from the Tone option. You can also change the volume of the tone of severity of touch vibration here.
In the past few weeks, I have received text messages from unknown email addresses. These messages contain the words from a text message received from a friend a few hours earlier. Within a few minutes,...
Sounds like you have been hacked. You should change your pass word and if you had a question. Change it as well. When you change your password use some capital letters as well as small case letters and put some numbers in as well. do not use common words as hackers can figure them out as well.
4answers
No New Email Alert Sound or Vibration
BEWARE!! Don't get trapped with the scammers. visit official AT&T help Website or call them for proper guidance.
https://www.att.com/
1 888 211 0387 ATT Email Customer Service Phone Number
BBM isn't sending or receiving messages. I've pulled the battery twice. Empty all emails and text messages and cleared all BBM chats. It worked breifly last night then off again!!! HELP!!
Hi there, It sounds like you're having problems with your data access. I would do a few things: 1) Send an e-mail - if you cannot do this, then you have no data access at all. If that's the case, call your carrier and tell them about your problem. It's not a problem with your device, but with your service provider. 2) If you CAN send e-mails, sometimes BBM just gets stuck. If you've already been waiting for longer than 10 minutes, you need to call your carrier. Tell them you need your service books resent. That will often fix your problem. Good luck! Alex
Whenever i get a new text message, my phone only blinks and does not vibrate how do i get my phone to vibrate?
Go to Menu>Settings>personal>profiles>select desired profile>options>personalize>message alert tone>
here you choose vibrate, none for off or any ringtone that you may have... select it and ok it
1helpful
My AT&T Xenon LG not receiving texts. A friend thought it would be a funny joke to send copy-and-paste of a lengthy website 50 times as a text. Now I am unable to receive texts; however, my friends...
Did you ever find a solution to this problem? The exact same thing happened to my friend two days ago. Someone sent them the same message repeatedly, and he can no longer receive any messages, other than multimedia.
1helpful
My LG enV VX9900 keeps turning off whenever I try to make a call. However, I can receive calls and send and receive texts.
If your phone is battery gets low for a short period of time then replace your phone battery, it is faulty or not fuctioning well. You can text or recieve calls but it may not take longer and when you try to make a call it suddenly shut down. So it is better to replace your battery with a new one to solve your phone problem.
Same text message again and again.
reboot your phone, try to remove your battery and putting it back after a few seconds... if problem still persist contact yer network provider...
For the past couple days I've been receiving multiple (up to 100!) copies of emails that are sent to my yahoo account. Can you help me correct this bug?
I resolved the problem myself. Apparently the mailbox was so full that it was giving an incorrect message that the new emails hadn't been received yet, so kept accepting them over and over again. So, I got to work deleting old emails that I no longer need. I emptied the trash can, too. I filed the unread emails in a folder labeled "Open These" till I can sort through them and figure out which ones to actually save. my Inbox has only a few emails in it, and I'm receiving no more multiple copies of emails! Actually, my email is working fine now.
Jan 25, 2009 • Yahoo Mail
5answers
My new lg ux260 is extremely slow to recognize text entries. Also, when sending a text, it sent to everybody in a certain user group as opposed to the individual the text was addressed to
for the problem of it being slow to recognize it when you're typing, mine does that too..but only when my phone's on silent or vibrate..so i'm not sure why that would be a reason, but that's what it does.
May 02, 2008 • Cell Phones
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
