Casio DB360G-9A 30 Pages Telememo Watch Logo
A
Anonymous Posted on Apr 06, 2014
How do I change the analogue time of my citizen navihawk watch to match the ditital time
Reset time on my citizen navihawk blue angels wr100
search google for the manual: citizen navihawk manual pdf
3helpful
1helpful
Hi I have a citizen red devils navihawk world time watch. when i change the battery and everything is change and i can not set it. I also lost my manual book and I would lik to have the imformation set my...
You can get instructions from the Citizen web site.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on "get setting instructions"
or
Go to "citizen.com" and click on "watch finder".
Put your watch model into the search box on the left and click on
"search".
Click on the watch to view details.
On the right is a small menu, click on "get technical info"
On the right you you will see a list of instructions you can download.
3helpful
I have citizen navihawk and the alarm chime is not working. What could be the problem??
Did this start after you had the battery changed? It is not uncommon for the alarm contact spring to get broken off that way.
My Citizen Navihawk analog hands work, LCD Blank??
Being able to tap it and bring it back is a sure sign that there is a contact problem most likely in the circuit board. This is the worst case scenario. I would try going to a watch maker/technician to see of having the watch AC'd or reset fixes the problem. If not then I would have them look at the circuit board/movement. This may have been damaged during battery placement from too much pressure.
If you have trouble finding a qualified watch maker/technician you can go to Citizen.com to look up their service center or an authorized service center near you.
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
