The ERR:INVALID DIM error message may occur
if you are trying to graph a function that does
not involve the stat plot features. The error can
be corrected by turning off the stat plots. To
turn the stat plots off, press y ,and
then select 4:PlotsOff.
• You specified a list dimension as something
other than an integer between 1 and 999.
• You specified a matrix dimension as something
other than an integer between 1 and 99.
• You attempted to invert a matrix that is not
square.
SOURCE: Plotting Points
you can reset all variables, without losing all your programs. you can hit 2nd>Mem(plus symbol)>reset>All ram Then verify that you wish to do so... It should reset to a working condition... If it doesn't then you may need to lose your programs in order to get your calc to a working condition.
SOURCE: when i try to graph a scatter plot on my ti-83
Your stat plots are on, and may not be filled out/ correctly filled out.
go to [Y=] and go up to the stat plots ([Plot 1], [Plot 2], [Plot 3] ) and turn off the ones that are "ON" ( highlighed black w/ white text.) and press [ENTER] on the ones that are on and the problem is no more.
SOURCE: my graphing calculator won't graph anything
Go to your stat plot screen, and select option 4 (PlotsOff), Press Enter, and try to plot a normal graph again
SOURCE: INVALID DIM error! help me!
Here is what the manual says
INVALID DIM : The dimension of the argument is incompatible with th current operation. (As dimension of a matrix, a list).
You can tell us more about what your were trying to do, we may able to help. Reset memory to default, the error may disappear.
[2nd][MEM][7][2][2] Defaults set.
Hope it helps.
SOURCE: WHen trying to graph anything, ERR: INVALID DIM
The easiest and quickest way to start graphing is to reset the RAM. Press [2nd][MEM][7:Reset][1:All Ram][2:Reset], then [CLEAR] to clear the RAM Cleared Message and go to the main screen.
Hope it helps.
