In order to select additional graphs, the Transformation Graphing Application will need to be uninstalled from the TI-83 Plus Family and TI-84 Plus Family. Uninstalling the Application does not erase it from the calculator, it disables it from interfering with the normal graphing modes. Below are the steps to successfully uninstall the Application.
• Press [APPS] key
• Select Transfrm from the menu
• Press 1:Uninstall
See cap images below
SOURCE: Graphing
Hi, you can try uninstalling the transformation app in your calculator. This does not really uninstall your application, it only prevents it from interfering with it. You should be able to graph multiple functions after that.
1) Go to APPS
2) Press Transfrm
3) Click Uninstall
SOURCE: TI-84 Plus Calculator will not turn on, says ram is cleared
Thats because the OS is corrupt. Follow the manual and reload the OS, try the 2.43 OS
SOURCE: My Graphing calculator has no x or y axis. Its all Blank.
Press the 2nd Button then the ZOOM button. Make sure that AxesOn is highlighted. If not, move your cursor down until you on AxesOn and press ENTER.
If AxesOn is highlighted, then it is probably your window. Press ZOOM, then 6.
SOURCE: I can't graph on my ti-84 plus silv. edition
More than likely, you've put in a number in the xmin or xmax that is not correct. Example....you put in an xmin of 10 and an xmax of -10 which would be backwards. This could also happen in the ymin or y max.
The easiest way to fix this is to press zoom 6 which wil get you back to the default graph of xmin of -10, xmax of 10 and ymin of -10 and y max of 10.
If you can't see your graph on this screen and need to change the window, just be sure the number in the min for both x & y is smaller than the number in the max. You change your window size by pressing the window button.
SOURCE: TI-84 Plus LCD display broken. Is replacement available?
Contact [email protected] or www.ti.com/calc .
Hope it helps
