Dryers Logo
Posted on Jun 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error message only prior to the rinse cycle,not filling correctl
The washer, a GE Profile Harmony( WPGT9350COPL), runs fine until the rinse cycle. For a "everyday,casual" selection, the rinse cycle comes on with about 16 minutes remaining. Just prior to this rinse cycle, an error message appears reading "Machine not filling properly,check hoses,etc".There are two test buttons below testing cold water and hot water. The hot water works fine, but the cold does not work. To finish the wash, I keep pressing the hot water test button until the maching shifts to the rinse cycle. What can I do to activate this cold water function just at the rinse cycle
Appreciate any suggestions,
Robert
Anonymous
Level 3:
President:
  • Master 1,865 Answers
  • Posted on Jun 15, 2009
Anonymous
Master
Level 3:
President:
Answers
1865
Questions
0
Helped
599462
Points
5720
The cold water solenoid valve seems to have failed on you. They're easy to replace and can be purchased at any appliance parts company
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 11, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
482
Points
My ge profile harmony Washer model # wpgt9350 copl will not do anthing and gives message that reads " problem detected in unit"please help..
I have a GE Harmony Profile top load washer. It is stuck on filling during the rinse cycle. It usually stays at 18 minutes for about 15-20 minutes. I usually start adding buckets of water to get it going....
when washers go into rinse cycle they use cold water so the clothes don't rinkle,i would say that you have a bad water valve located on the washer,you can try to run the wash at the beginning just with cold water,if the water comes in slow you have a bad valve,you can then run it on just hot water and see if there's a difference in how fast it fills.the strange thing is that it should pop up with an error code after 6 or 8 minutes because the washer is filling to slow,have you seen any codes come up?if it is the valve the part number is WH13X10017 and that valve is under the top console
3helpful
3answers
17helpful
2answers
Have a message on GE Profile Harmony washer that say " a problem has been detected with the unit" help?
Washers - Harmony Washer Error Message or Code
The Harmony washer electronics can automatically determine if problems exist with the machine. Sometimes an error code can also be present because of things the machine cannot control: like changes in house voltage, water pressure, or temperature.
"A problem has been detected with this unit" will be displayed on the screen.
The most common solution for this message is to turn the machine OFF and then ON. However, this message will sometimes cause the control to stop the machine from working. With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control.
Solution:
1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Top loading GE color profile washer (wpse4200a) won't fill
You may have a water supply problem. There is a mesh screen in the hoses where they hook to the washer. Make sure they aren't clogged up
Washer will not fill in rinse cycle.
hi, When the washer acts up in the rinse cycle, will it try and fill and then the water starts going out the drain hose? If this is the case, the drain hose is either needs to be raised to be as high as the top of the washer or, it needs to have a loose fitting where it goes into the drain pipe so it can have air **** back into the drain hose after it releases the wash water.
i know this is a lot of info that might not even be the answer but, I am giving you the most common fix. Please let me know if I have answered your question or let me know if I can assist you further.
If this does not seem to be the answer, maybe I need clarification.
Vic
1helpful
I need a owners manual.
CALL GE AND REQUEST A OWNERS MAUAL. GIVE THEM YOUR WASHER MODEL NUMBER AND TYPE OF WASHER IT IS. GOOD LUCK.
RODNEY
5helpful
GE PROFILE WASHER M# WPGT9350COPL
1 press power ( to wake up washer)
2 press Home ( it may already show HOME)
3 press HELP
4 press and hold MY CYCLES and BACK (for 3 to 5 seconds)
the service mode diagnostics screen will come up
it will show what errors are recorded..( if more button is displayed then also go to next list)
be sure to write them down exit will clear the codes and run a test
let me know what it tell you I can help...
2helpful
WASHERS WILL START
GE Profile Harmony
3 press HELP
Let me know what the errors are I can help..
Top GE Dryers Experts
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
