Korg Pa800 Synthesizer Logo
Carlos Mendoza Arimana Posted on Mar 28, 2014
En el pa korg 500 de error aparece os lectura de archivos Que Se Puede HACER
Trate de regresar mi pa500 corg al modo de fabria cpero solo lo malogre necesito repararlo me sale esta pregunta error loading os packager eso me sale la ultimo q puedo hacer para recuperar todos los archivos d emi teclado...
mre electronics
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on Mar 29, 2014
mre electronics
Contributor
Level 1:
New Friend:
Answers
19
Questions
Helped
14339
Points
20
Carlos Hi
despues de formatear el equipo todo tiene que volver como recibistes el pa 500 nuevo de fabrica
1 Related Answer
Fred Yearian
  • 5603 Answers
  • Posted on Feb 25, 2011
SOURCE: hi there i have a
Do a factory reset. Refer to your manual or use google to find the procedure.
I have an EMX5016CF mixer. 2 of the channels have both the peak and signal lights permanently on. What does this mean?
Hi Safa Mashat, the problem with the two lights, can have several origins
First, disconnect the signal that enters these two channels and check if they are still on, but they are, the problem is in the cable or device that is connected to that line
If the fault still continues, it is most likely that the two-channel input stage has been damaged.
In this case if you have technical knowledge, I send you the service manual link
If not, I suggest you look for a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Safa Mashat, el problema que tenga las dos luces, puede tener varios origenes
Primero, desconecta la se?al que le entra a estos dos canales y verifica si siguen prendias, sino lo estan, el problema esta en el cable o aparato que esta conectad0o a esa linea
Si aun continua la falla, lo mas probable que se haya da?ado le etapa de entrada de los dos canales
En este caso si tienes conocimientos tecnicos , te envio el link del manual de servicio
Sino, te sugiero buscar un servicio tecnico especializado
Espero puedas resolver el problema
Saludos Franco Dosil
https://elektrotanya.com/yamaha_emx5016cf_sm.pdf/download.html
https://mx.yamaha.com/files/download/other_assets/5/334285/emx5016cf_es_om_d0.pdf
Jul 21, 2019 • The Music
1helpful
How do you open the fuse tray on a peavey 4b mixer to check on no power?
Hello John, the fuse is in the power input of Tu Peavey
If you notice, on the rear panel, where the power cord is plugged in, up on the same connector, you will see a horizontal cover that can be removed by placing a tip on the underside of this cover and pulling outwards, it will come out a plastic element, which holds the fuse, this element has an intermediate space where another spare fuse can be housed
I hope my comment has been useful and you can take out the fuse
Keep in mind that if you blow the fuse, because I pass, check the cables and speaker connectors, that do not have any short circuit
Hola John, el fusible se encuentra en la entrada de energ?a de Tu Peavey
Si te fijas, en el panel trasero, donde va enchufado el cable de corriente, arriba en el mismo conector, vas a ver una tapa horizontal que se puede sacar poniendo una punta del lado de abajo de esta tapa y haciendo fuerza hacia afuera, saldr? un elemento pl?stico, que sostiene al fusible, este elemento tiene un espacio intermedio donde se puede alojar otro fusible de repuesto
Espero que te haya servido mi comentario y puedas sacar el fusible
Ten en cuenta que si se quemo el fusible, porque paso,revisa los cables y los conectores de parlante, que no tengan ning?n cortocircuito
https://www.google.com/url?sa=i&source=images&cd=&ved=2ahUKEwiUpJWv4bDiAhUTIrkGHXfyDoQQjRx6BAgBEAU&url=https%3A%2F%2Fwww.tme.eu%2Fhtml%2FES%2Fconectores-machos-iec-con-proteccion-de-fusible-para-panel-schurter%2Framka_3250_ES_pelny.html&psig=AOvVaw3u39E87rodMysi11CwjaR6&ust=1558670267837577
My behringer eurodesk sx3242fx has a problem with the MAIN OUT XLR (L&R)....LEFT side is not working what is the problem?
Hi Ezra, for the failure you describe, you may have a problem with the Main Insert connectors, more presumably on the left, this connector has the function of interleaving some type of processor in the stages of the master L and R, and has some contacts internal that get dirty and produce false contact in the passage of the output signal
Try cleaning it with some contact cleaner, put a small amount of cleaner and with the help of a plug, put it on and take it out several times in order to make the cleaner work, do the same with the right channel, because the same fault will appear. , sometime
If this does not work, you would apparently have problems with the left master dimmer potentiometer on the corresponding electrical circuit
I sent you the link to download the user manual of your Behringer
I hope you serve my suggestions and manage to make the left exit work
Hola Ezra, por la falla que describes, puedes tener un problema en los conectores Main Insert , mas presisamente en el Izquierdo, este conector tiene la funcion de intercalar algun tipo de procesador en la etapas de los master L y R, y cuenta conunos contactos internos que se ensucian y producen falso contacto en el paso de la se?al de salida
Prueba limpiarlo con algun limpiador de contacto, pon poca cantidad de limpiador y con la ayuda de un plug ve colocandolo y sacandolo repetidas veces a los efectosn de que el limpiador actue, haz lo mismo con el canal derecho, porque ya le aparecera la misma falla, en algun momento
Si esto no da resultado, aparentemente tendrias problemas con el potenciometro atenuador master Izquierdo on el circuito electrico correspondiente
Te envio el link para que descargues el manual de usuario de tu Behringer
Espero te sirvan mis sugerencias y logres hacer funcionar la salida Izquierda
http://www.manualsbase.com/es/manual/downloadmanual/119881 https://manualsbrain.com/es/manuals/809021
2helpful
Kord pa 50 enciende, pero no funciona
ola claudio
tienes que resetear el organo y despues cargar el os
Quiero conectar la guitarra
Se necesitan dos cuarto de pulgada a los adaptadores de RCA. El uso del adaptador, conectar la guitarra a la entrada y la salida a su amplificador o dispositivo que desee.
Por favor, perdone mi espa?ol, ya que no lo hablan.
3helpful
Como puedo conectar mi Consola Peavey de 32 Fx en mi mac OS X 10 y tengo instalado Pro Tools M-powered y pro tool HD necesito que me reconozca los 32 canales para poder grabar en multipista.
Necesitas los drivers que deber?an venirte en un cd con la consola. Si no instalas eso, la PC no reconoce los AD converters que usa cada canal , que ser?a como agregar la misma cantidad de tarjetas de sonido nuevas, y es imposible que puedas grabar.
Si no tenes el CD, deber?as ingresar en la pagina del fabricante para descargarlos.
Top Korg Music Experts
john h
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Korg Music Expert? Answer questions, earn points and help others
