The BOF message on a Hobart Ecomax 652 dishwasher indicates a "boiler filling" issue, which means the dishwasher is unable to fill the boiler with water. Here are some things you can try:
- Check the water supply: Make sure that the water supply to the dishwasher is turned on and there is enough water pressure. If there is low water pressure, it may cause the BOF message.
- Check the water inlet valve: If the water inlet valve is not functioning properly, the dishwasher may not be able to fill the boiler with water. Make sure that the inlet valve is not clogged and is getting power.
- Check the level probe: The level probe detects the water level in the dishwasher. If it is not working properly, the dishwasher may not be able to fill the boiler with water. Check the probe to ensure it is clean and in good condition.
- Check the boiler: The BOF message may also indicate a problem with the boiler itself. Check the boiler to see if there is any damage or blockage.
If these steps do not solve the issue, it may be best to contact a professional technician to diagnose and fix the problem.
