My 22662100 kenmore washer does not completely drain and clothes remian to wet.
The washer does not drain enough. After the spin the clothes are still too wet. There seems to be some water still in the bottom of the tub. If you move the tub around you can hear water slushing around. After a second spin there is still too much moisture in the laundry. Neither the cycle or the load size change this. This makes for a huge increase in dry-time. I have cleaned out the drain hose from the washer to the drain and found no blockage. Is there an internal filter that could be plugged or a new pump. Sometimes there is a very bad mouldy odor that comes from the washer. Thanks
Re: My 22662100 kenmore washer does not completely drain...
If the pump isnt bad, there is a sensor mounted in the back o of the unit that controls draining. It is near the water outlets and have wire connectors. Part.com or appliance parts.com to find replacement
As far as the water not draining completely could be blockage inside the drain pip or near/around the pump place a deep tray under and see if you can disconnect the drain pip going to the pump and after and clean it. Try spin sycle without clothes to reduce the water hope that give you an idea and help god bless
The clothes are wet after spinningWhen the clothes are wet at the end of a cycle, check these:Motor couplerSpin cycleSiphoningWater-inlet valveMotor couplerTo test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.Spin cycleIf the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.SiphoningIf the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.Water-inlet valveWater-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Spin cycle
Siphoning
Water-inlet valve
I do not have this kind of washer, but I had same problem with my washer and I found the drain trap was full not allowing washer to completely drain. Hope this helps, Good Luck!
