SOURCE: help please stuck in service menu
Techman, I have the following details into Service Mode: 15.1 Quick entry to service mode: TOP PREVIOUS NEXT When minor adjustments need to be done to the electronic controls, the method for entering the service mode without removal of the cabinet back is as follows, using the remote control: Select SET-UP icon, enter ?Program CH? and select CABLE mode in ?Input Setup? option. Select TIMER icon and set SLEEP time for 30 Min. Press ?OK? then VOL up to exit menus. Tune to the Channel 124. Adjust VOLUME to minimum (0). Press VOL ← (decrease) on receiver. Red ?CHK? appears in upper corner. To toggle between aging and service modes: While the ?CHK? is displayed on the left top corner of the CRT, pressing ?OK? and ?VOL? UP on the TV simultaneously will toggle between the modes. Red ?CHK? for service modeand yellow ?CHK? for aging. Press POWER on the remote control to display the service adjustment modes menu, select adjustment by pressing the VOL right/left buttons and CH up/down buttons on the remote and OK to enter the adjustment. Service mode menu TOP PREVIOUS NEXT Have you gotten this to work?
SOURCE: LOCKED displays when attempting to eject disk from SA-HT670
i have a panasonic SA-HT720 and it displayed locked anytime i wanted to eject discs so i found out that dad27's solution was the best and holding down the stop and power buttons also locks the system as well as unlocking it. God richly bless u dad27 u really helped me out
SOURCE: Lost the remote, manually need to access Menu button
VCRs since the early '90s have limited function with the machine located controls, and a remote is necessary to get into most setup options, probably including the channel add/delete. Many VCRs do have an auto program mode which searches for active channels, but I'd guess this also is activated via remote. A universal remote which specifically has the capability of performing the advanced functions is probably available. Look here for an exact http://www.electronicadventure.us/panasonic.htm Part number is VSQS1418 according to this site for PV4501.
SOURCE: Camera froze up w/ no button function
hello, these units have a very fine zoom switch and can get damaged by a drop or fine sand. the zoom switch sits under the actual button. if you turn the camera on in camera mode and the display is showing the zoom on screen display then you know it is the switch.
SOURCE: How do I access the jvc gy-hd100 admin menu
Push during 2, 3 seconds the "status" button on the side of the camera.
