Whirlpool LGV4634JQ Gas Dryer Logo
A
Anonymous Posted on Mar 14, 2014
Lgr4634jq not moving - Whirlpool LGV4634JQ Gas Dryer
1helpful
Lyrics to Move along
Lyrics
Go ahead as you waste your days with thinking
When you fall everyone stands
Another day and you've had your fill of sinking
With the life held in your
Hands are shaking cold
These hands are meant to hold
Speak to me, when all you got to keep is strong
Move along, move along like I know you do
And even when your hope is gone
Move along, move along just to make it through
Move along
Move along
So a day when you've lost yourself completely
Could be a night when your life ends
Such a heart that will lead you to deceiving
All the pain held in your
Your hands are mine to hold
Move along
(Go on, go on, go on, go on)
When everything is wrong, we move along
Along, along, along
When all you got to keep is strong
[x3]Right back what is wrong
We move along
[fade out]
Move Along The All American Rejects
Car runs will move in all gears but does move
This does not seem like a problem. Selector moves, vehicle moves, what is the question?
My dryer won't heat. we replaced the thermal fuse and it heated for one cycle but won't heat anymore. It is a Whirlpool LGR4634JQ gas dryer.
Hi impenick...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks.
If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the
wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed
component. The switch is inside the dryer main housing near the door frame.
Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Check for continuity you should have none with door open, and should have a reading when closed.
If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause
heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the
thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape
or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged
with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's
plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace an element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
2helpful
Passenger seat jammed won't move backward
Should be a coat-hanger type hard steel wire running from lever to move seat to move 2 levers, one on each side of seat and this allows it to travel on a toothed track.  Could just be dirt and stuff lodged in this track.  Move these levers out and seat will move but both levers have to be moved to move seat - if spring is off on one side will only move on one side.  Just reach under with light and manually move these levers and push on seat.
I'm Making a batch File that moves and copy files, not working.
@Echo Off
:start
set /p 1=Please Enter Directory and Name of file you would like to move
set /p 2=Please Enter Directory of where the file will go
set /p 3=please select 1 of 2
options 1: copy 2: move
if %3%==move goto a
if %3%==copy goto b
:A move %1% %2%
goto c
:B copy %1% %2%
:C echo end
28helpful
3answers
Blocks puzzle # 57 in Nintendo DS 50 Classic Games impossible?
  1. Top Icon right (3 moves)
  2. Left Icon left (1 move)
  3. Sedond Left Icon left (1 move) clears 2 Icons
  4. Left Icon right (1 move) clears 3 Icons
  5. Top Left Icon left (2 moves) ends up on bottom
  6. Middle row Second Icon left (2 moves)
  7. Middle row Third Icon left (2 moves) clears 2 Icons
  8. Middle row Second Icon right (1 move) ends up on bottom
  9. Middle row Right Icon left (4 moves) clears 3 Icons
  10. Top Icon left (1 move) clears 2 Icons
  11. The Rest Is EASY!! (2 moves) clears 4 Icons
6helpful
2answers
Puzzles 130 Too Many Queens 5 --- 132 Princess's Escape
puzzle 130:Assuming on a chess board 8x8 that each square is numbered 1-64 top left to right.Place a queen on each of these squares 3,13,18,32,33,47,52 and 62 bobs yer uncle
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
