Ringing is assigned in system programming, so if your phone doesn't ring you can't change that unless you have person on site who works on the system at that level. Some places use the night mode feature to make certain phones ring in day mode, and others to ring in night mode. Not very likely but sometimes the mode gets switched at places who don't realize they have another mode, suddenly only 2 phones ring instead of ...5. Feature,80,Feature, is the code to switch back and forth on a Pro II, an Elite, and an IPK system. This would be done at the reception phone. These phones also work on several other systems so don't know if this works for you. Or maybe you set Do Not Disturb, which would keep your ringer off.
It sounds like you don't have it programmed to ring. The volume controls the sound, but programming controls the ringing. Try night mode (782 from extension 101) to put it into night and test again, or check out the sytsem programming for ring modes.
Flash the phone all will be ok boss. You will need a flashing device usually a flashing tool if u do not have one I suggest you take the phone to the nearest Nokia care center and they will do it for you
We may need to know the exact system you are using and the model of phone.
Also we will need to know the group number the system is using for night mode. Normally group number 601 is day and 602 is night. If you call 602 that would ring the phones currently in night. Also you can try calling at night and watch the screen of the phone that rings if its a smaller screen phone press the info button while its ringing and one of the options will show the night ring group number as well.
Respond to this and I can further help.
there r three modes.
1)ring mode.
2)vibration mode.
3)silence mode.
so it would be on silence mode.just make it ring mode from silence mode.
which can be done by going into settings then in to ringer and volume option.in that you can select.
thanks.
This phone allows you to independently set ring and vibrate modes. When you access "Call Vibrate" to set the mode, also visit the "Call Ringtone" menu to turn off the ringer.
You may want to leave the vibrate mode OFF and your ring tone ON and use the quick keys to switch between ring and vibrate. Two ways to do this, push and hold the # key to switch between normal mode (the settings you chose in "Call Ringtone" and "Call Vibrate") or use the side volume button to access the "Master Volume" and select "All Off", "Vibrate" or a ring tone volume.
All you have to do is hold the pound (#) button down. It will then say exit silent mode. If you ever want to put your phone back in silent mode, just hold the pound (#) button down.
Go to tools then ring styles using the "-" at the top center of the keypad. It will be set to vibe then ring, press "change" alter the style to vibe, vibe then ring, silent, loud or whatever you like. That is also where you find what ringtone is used for the ring.
